- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 6, 2025
Log forwarding does not work in Proxy setups because the proxy environment variables were not set in the logging pods.
Set the
http_proxy,https_proxyandno_proxyenvironment variables. Example:export http_proxy=http://<proxy>:3128 export https_proxy=http://<proxy>:3128 export no_proxy=<fqdn>,.<fqdn>,10.0.0.0/8,kerberossql.autosuitead.local,kerberospostgres.AUTOSUITEAD.LOCAL,rook-ceph-rgw-rook-ceph.rook-ceph.svc.cluster.local,localhost,127.0.0.1,kubernetes,kubernetes.default,kubernetes.default.svc,kubernetes.default.svc.cluster,kubernetes.default.svc.cluster.local,.svc,.svc.cluster,.svc.cluster.local,.svc.cluster.local.,.uipath.svc.cluster.local,argocd-repo-server,istiod.istio-system.svc,logging-operator-logging-fluentd.logging.svc.cluster.local,.local,.cluster,ai-helper-svc,ai-pkgmanager-svc,ai-deployer-svc,ai-appmanager-svc,ai-trainer-svc,studioweb-backend,studioweb-frontend,studioweb-typecacheexport http_proxy=http://<proxy>:3128 export https_proxy=http://<proxy>:3128 export no_proxy=<fqdn>,.<fqdn>,10.0.0.0/8,kerberossql.autosuitead.local,kerberospostgres.AUTOSUITEAD.LOCAL,rook-ceph-rgw-rook-ceph.rook-ceph.svc.cluster.local,localhost,127.0.0.1,kubernetes,kubernetes.default,kubernetes.default.svc,kubernetes.default.svc.cluster,kubernetes.default.svc.cluster.local,.svc,.svc.cluster,.svc.cluster.local,.svc.cluster.local.,.uipath.svc.cluster.local,argocd-repo-server,istiod.istio-system.svc,logging-operator-logging-fluentd.logging.svc.cluster.local,.local,.cluster,ai-helper-svc,ai-pkgmanager-svc,ai-deployer-svc,ai-appmanager-svc,ai-trainer-svc,studioweb-backend,studioweb-frontend,studioweb-typecache -
Execute the following script which ingests the environment variables into the logging pods and restarts them.
#!/bin/bash set -euo pipefail APP_NAME="logging" NAMESPACE="argocd" HTTP_PROXY="${http_proxy:-}" HTTPS_PROXY="${https_proxy:-}" NO_PROXY="${no_proxy:-}" # Create a temporary JSON patch PATCH_FILE=$(mktemp) cat > "$PATCH_FILE" <<EOF { "spec": { "source": { "helm": { "parameters": [ { "name": "logging-operator.env[0].name", "value": "http_proxy" }, { "name": "logging-operator.env[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.env[1].name", "value": "https_proxy" }, { "name": "logging-operator.env[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.env[2].name", "value": "no_proxy" }, { "name": "logging-operator.env[2].value", "value": "${NO_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[0].name", "value": "http_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[1].name", "value": "https_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[2].name", "value": "no_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[2].value", "value": "${NO_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[0].name", "value": "http_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[1].name", "value": "https_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[2].name", "value": "no_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[2].value", "value": "${NO_PROXY}" } ] } } } } EOF # Patch the Argo CD Application kubectl patch application "$APP_NAME" -n "$NAMESPACE" --type merge --patch-file "$PATCH_FILE" # Cleanup rm -f "$PATCH_FILE" echo "Patched Argo CD Application '$APP_NAME' with proxy parameters." echo "Restarting logging pods..." kubectl rollout restart deploy/logging-logging-operator -n logging kubectl rollout restart sts/logging-fluentd -n logging kubectl rollout restart ds/logging-fluentbit -n logging echo "Rollout restart completed"#!/bin/bash set -euo pipefail APP_NAME="logging" NAMESPACE="argocd" HTTP_PROXY="${http_proxy:-}" HTTPS_PROXY="${https_proxy:-}" NO_PROXY="${no_proxy:-}" # Create a temporary JSON patch PATCH_FILE=$(mktemp) cat > "$PATCH_FILE" <<EOF { "spec": { "source": { "helm": { "parameters": [ { "name": "logging-operator.env[0].name", "value": "http_proxy" }, { "name": "logging-operator.env[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.env[1].name", "value": "https_proxy" }, { "name": "logging-operator.env[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.env[2].name", "value": "no_proxy" }, { "name": "logging-operator.env[2].value", "value": "${NO_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[0].name", "value": "http_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[1].name", "value": "https_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.logging.fluentd.envVars[2].name", "value": "no_proxy" }, { "name": "logging-operator.logging.fluentd.envVars[2].value", "value": "${NO_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[0].name", "value": "http_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[0].value", "value": "${HTTP_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[1].name", "value": "https_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[1].value", "value": "${HTTPS_PROXY}" }, { "name": "logging-operator.logging.fluentbit.envVars[2].name", "value": "no_proxy" }, { "name": "logging-operator.logging.fluentbit.envVars[2].value", "value": "${NO_PROXY}" } ] } } } } EOF # Patch the Argo CD Application kubectl patch application "$APP_NAME" -n "$NAMESPACE" --type merge --patch-file "$PATCH_FILE" # Cleanup rm -f "$PATCH_FILE" echo "Patched Argo CD Application '$APP_NAME' with proxy parameters." echo "Restarting logging pods..." kubectl rollout restart deploy/logging-logging-operator -n logging kubectl rollout restart sts/logging-fluentd -n logging kubectl rollout restart ds/logging-fluentbit -n logging echo "Rollout restart completed"
