Last updated Dec 15, 2025
Cross-deployment model feature comparison
We aim to provide feature parity between our Automation Suite deployment models. However, there will always be some differences you should be aware of.
If you need to deploy Automation Suite in different supported environments, refer to the following guides:
User scenario/FeatureAutomation Suite on LinuxAutomation Suite on AKSAutomation Suite on EKSAutomation Suite on OpenShift
Service capabilities
Orchestratoravailableavailableavailableavailable
AI Centeravailableavailableavailableavailable
AI Center with external orchestrator (standalone)availablenot availablenot availablenot available
Appsavailableavailableavailableavailable
Action Centeravailableavailableavailableavailable
Automation Hubavailableavailableavailableavailable
Automation Opsavailableavailableavailableavailable
Data Serviceavailableavailableavailableavailable
Document Understandingavailableavailableavailableavailable
Insightsavailableavailableavailableavailable
Integration Servicenot availableavailableavailablenot available
Automation Suite Robotsavailableavailableavailableavailable
Process Miningavailableavailableavailableavailable
Task Miningavailableavailableavailablenot available
Test Manageravailableavailableavailableavailable
Communications miningnot availablenot availablenot availablenot available
Studio Webnot availableavailableavailablenot available
Architecture
KubernetesRancher RKE2AKSEKSOpenShift
Databases
  • MS SQL
    Note: Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
  • PostgreSQL for Process Mining Airflow database
    Note:
    Automation Suite 2024.10.3 or higher.
Storage
  • Option 1: Object Storage (Ceph)
  • Option 2: Object storage external to the cluster
UiPath® provides Ceph.
  • Object Storage: Azure Blob
  • Filesystem: Azure Filesystem
  • Block Storage: Azure Disks
  • Object Storage: AWS S3
  • Filesystem: AWS EFS
  • Block Storage: AWS EBS
  • Objectstore - Azure Blob, AWS S3, S3-compatible objectstore
  • File System - StorageClass for workloads that do not require replication
  • Block storage - StorageClass with replication for the persistent volume
Service Mesh and Routing
OSS Istio Service Mesh
Routing via envoy ingress gateway
Routing via WASM plugin
OpenShift Service Mesh
OPA
OSS Gatekeeper
OSS Gatekeeper
OSS Gatekeeper
not available
Monitoring
OSS Prometheus and Grafana
not available
Caching
Embedded Redis within the cluster and provided by UiPath®
Cloud Redis outside the cluster and managed by customer
  • External Redis Enterprise
  • OpenShift Redis Enterprise Operator managed by customer
Logging Aggregation
OSS Fluentd/Fluent-bit
OSS Fluend/Fluent-bit
not available
Cert Manager
OSS Cert Manager
OSS Cert Manager
OSS Cert Manager
OpenShift Cert Manager Operator
Deployment tool
OSS ArgoCD
OSS ArgoCD
OSS ArgoCD
OpenShift GitOps Operator
Deployment scenario
Single Node (Non-production)
available
not available
not available
not available
Multi Node (HA)
available (requires additional HAA license)
available
available
available
Online
available
Offlineavailable
available
available
available
Deployment method
Advanced CLIuipathctl
uipathctl
uipathctluipathctl
Interactive Installer
available (InstallUiPathAS.sh)
not available
not available
not available
GUI-based wizard
not available
available
GUI-based wizard for generating the cluster configuration file. For details, see Generating the configuration file using a wizard.
available
available
Marketplace
available (AWS QS Only)
not available
not available
not available
Installation
A la carte product selection
available
Custom domainavailableavailableavailableavailable
Custom certificatesavailableavailableavailableavailable
Hardware requirements validationavailableavailableavailableavailable
Proxy configurationavailableavailableavailableavailable
Optional OSS/fabric component
not available
availableavailable
not available
Enterprise grade features
Disaster Recovery
available (Active/Passive and Active/Active deployments)
not available
(Multi-zone architecture for UiPath® services without zone affinity. Insights not supported.)
not available
not available
Backup/restoreavailableavailableavailable
You must use your own backup and restore solution.
Upgrade
available
Troubleshooting
Support bundleavailable
(uipathctl)
available (uipathctl)
Diagnostic toolavailable
(uipathctl)
available
(uipathctl)
Health Checks
not available
available (uipathctl) available (uipathctl) available (uipathctl)
Security
FIPS enabled host
available
available
available
available
Gatekeeper/OPA policyavailableavailableavailablenot available
Network policyavailableavailableavailablenot available
Hardened UiPath® service container imagesavailableavailableavailableavailable
ArgoCD SSOavailable (LDAP only)
available
available
not available
mTLS for service communication
available
available
available
available
Migration options
Standalone Orchestrator to Automation Suite full migrationavailableavailableavailable
available
Standalone Orchestrator to Automation single tenant migration optionsavailableavailableavailable
available
Automation Suite on Linux to Automation Suite on AKS/EKS
available
available
available
N/A
Automation Suite on Linux to Automation Suite on OpenShift
available
N/AN/A
available
