Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
EKS input.json example
The following example shows input.json with all products enabled, mandatory and optional configuration parameters for Automation Suite on EKS. You can use this as reference and make changes as per your environment requirements.
Note that the minimum UiPath® product selection requires platform to be enabled. Make sure to replace all the username and passwords, including SQL connection strings.
  "infra": {
    "external_object_storage": {
      "bucket_name": "s3-sfd-ci-aseks3997852-common"
  "dataservice": {
      "bucket_name": "s3-sfd-ci-aseks3997852-dataservice"
    "enabled": true
  "platform": {
    "enabled": true
  "integrationservices": {
    "enabled": true,
  "studioweb": {
    "enabled": true,
  "orchestrator": {
    "enabled": true,
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
      "bucket_name": "s3-sfd-ci-aseks3997852-processmining"
    "enabled": true
  "insights": {
    "enabled": true
  "task_mining": {
      "bucket_name": "s3-sfd-ci-aseks3997852-taskmining"
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "aicenter": {
      "bucket_name": "s3-sfd-ci-aseks3997852-common",
      "port": 443,
      "fqdn": "s3.eu-west-1.amazonaws.com"
    "enabled": true
  "documentunderstanding": {
    "enabled": true
  "test_manager": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "asrobots": {
    "packagecaching": true,
    "packagecachefolder": "/uipath_asrobots_package_cache",
    "enabled": true
  "registries": {
    "docker": {
      "url": "registry.uipath.com"
    "helm": {
  "fqdn": "ci-aseks3997852.infra-sf-ea.infra.uipath-dev.com",
  "profile": "ha",
  "fabric": {
    "redis": {
      "hostname": "master.redis-ci-aseks3997852-v68qm-dszgx.u7xrbf.euw1.cache.amazonaws.com",
      "password": "----",
      "port": 6380,
      "tls": true
    "enabled": true,
    "storage_type": "s3",
    "create_bucket": false,
    "region": "eu-west-1",
    "use_instance_profile": true
  "kubernetes_distribution": "eks",
  "sql_connection_string_template": "Server=tcp:rds-ci-aseks3997852-9wvlq-wgpvc.cvzkeyeubtc9.eu-west-1.rds.amazonaws.com,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin;Password='SQL_PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://rds-ci-aseks3997852-9wvlq-wgpvc.cvzkeyeubtc9.eu-west-1.rds.amazonaws.com:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password={SQL_PASSWORD_PLACEHOLDER};encrypt=true;trustServerCertificate=true;loginTimeout=30;",
  "sql_connection_string_template_odbc": "SERVER=rds-ci-aseks3997852-9wvlq-wgpvc.cvzkeyeubtc9.eu-west-1.rds.amazonaws.com,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD={SQL_PASSWORD_PLACEHOLDER};MultipleActiveResultSets=False;Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=rds-ci-aseks3997852-9wvlq-wgpvc.cvzkeyeubtc9.eu-west-1.rds.amazonaws.com",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin:SQL_PASSWORD_PLACEHOLDER@rds-ci-aseks3997852-9wvlq-wgpvc.cvzkeyeubtc9.eu-west-1.rds.amazonaws.com:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
  "admin_username": "admin",
  "admin_password": "----",
  "storage_class": "ebs-sc",
  "storage_class_single_replica": "efs-sc",
  "ingress": {
    "service_annotations": {
      "service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
      "service.beta.kubernetes.io/aws-load-balancer-eip-allocations": "eipalloc-006ebfcf91bb32d86,eipalloc-076a653da0fdd627b",
      "service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
      "service.beta.kubernetes.io/aws-load-balancer-scheme": "internet-facing",
      "service.beta.kubernetes.io/aws-load-balancer-type": "nlb"
  "istioMinProtocolVersion": "TLSV1_3"
  "infra": {
  "dataservice": {
    "enabled": true
  "platform": {
    "enabled": true
    "enabled": true,
  "studioweb": {
    "enabled": true,
  "orchestrator": {
    "enabled": true,
    "testautomation": {
      "enabled": true
    "updateserver": {
      "enabled": true
  "processmining": {
    "enabled": true
  "insights": {
    "enabled": true
  "task_mining": {
    "enabled": true
  "automation_hub": {
    "enabled": true
  "automation_ops": {
    "enabled": true
  "aicenter": {
      "port": 443,
    "enabled": true
    "enabled": true
  "test_manager": {
    "enabled": true
  "action_center": {
    "enabled": true
  "apps": {
    "enabled": true
  "asrobots": {
    "enabled": true
  "registries": {
    "docker": {
    "helm": {
  "profile": "ha",
  "fabric": {
    "redis": {
      "password": "----",
      "port": 6380,
      "tls": true
    "enabled": true,
  "ingress": {
