Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
Meeting the Process Mining prerequisites
Note: You must take the steps in this section only if you run the Automation Suite installer with reduced privileges. If you can run the installer with admin privileges, you do not need to follow the instructions in this section.
Installing cert-manager
The Dapr installation for Process Mining requires cert-manager.
You can install cert-manager via Helm. For installation instructions, see the cert-manager documentation.
Installing Dapr
To install Dapr, take the following steps:
  1. Create an image pull secret in the <uipath> namespace. To create the image pull secret, you can use your typical workflow or take the following steps:
    registry= <registry_url> #provide the registry where the UiPath images are hosted
    username= <user_name> #provide the username which will be used for the authentication
    password= <password> #provide the password which will be used for the authentication
    namespace= <namespace> #namespace where you want to create a secret
    kubectl create secret docker-registry uipathpullsecret --namespace=${namespace} \
      --docker-server=${registry} --docker-username=${username} \
      --docker-password=${password} --dry-run=client -o yaml \
      | kubectl apply -f -registry= <registry_url> #provide the registry where the UiPath images are hosted
      | kubectl apply -f -
  2. Create the Argo application using the following YAML file:
    apiVersion: argoproj.io/v1alpha1
    kind: Application
    metadata:
      namespace: <argo_namespace>
    spec:
      destination:
        namespace: <uipath_namespace>
        server: https://kubernetes.default.svc
      ignoreDifferences:
      - jsonPointers:
        - /data
        - /stringData
        - /metadata
        kind: Secret
      - group: apiextensions.k8s.io
        jsonPointers:
        - /spec/conversion
        kind: CustomResourceDefinition
      - group: admissionregistration.k8s.io
        jsonPointers:
        - /webhooks
        kind: MutatingWebhookConfiguration
      project: <project_name>
      source:
        chart: helm/dapr
        helm:
          valueFiles:
          - values.yaml
          values: |
            global:
              registry: <target-registry>/daprio
              imagePullSecrets: uipathpullsecret
              mtls:
                enabled: true
              prometheus:
                enabled: false
              logAsJson: true
              actors:
                enabled: false
              ha:
                enabled: false
                replicaCount: 1
              rbac:
                namespaced: true
              seccompProfile: RuntimeDefault
            dapr_dashboard:
              enabled: false
            dapr_operator:
              watchInterval: 1m
              resources:
                requests:
                  cpu: 100m
                  memory: 100Mi
                limits:
                  cpu: "1"
                  memory: 200Mi
              watchNamespace: <uipath_namespace>
              deploymentAnnotations:
                sidecar.istio.io/inject: "false"
            dapr_sidecar_injector:
              allowedServiceAccounts: <uipath_namespace>:default
              resources:
                requests:
                  cpu: 100m
                  memory: 30Mi
                limits:
                  cpu: "1"
                  memory: 100Mi
              sidecarDropALLCapabilities: true
            dapr_sentry:
              resources:
                requests:
                  cpu: 100m
                  memory: 30Mi
                limits:
                  cpu: "1"
                  memory: 100Mi
            dapr_rbac:
              secretReader:
                enabled: false
              createClusterScopedObjects: true
        repoURL: <target-registry>
        targetRevision: <dapr-version>
      syncPolicy:
        automated:
          prune: true
          selfHeal: true
        retry:
          backoff:
            duration: 10s
            factor: 2
            maxDuration: 1m
          limit: 1000
        syncOptions:
        - CreateNamespace=true
        - RespectIgnoreDifferences=trueapiVersion: argoproj.io/v1alpha1
    kind: Application
    metadata:
    spec:
      destination:
      ignoreDifferences:
      - jsonPointers:
        - /data
        - /stringData
        - /metadata
        kind: Secret
        jsonPointers:
        - /spec/conversion
        jsonPointers:
        - /webhooks
      source:
        chart: helm/dapr
        helm:
          valueFiles:
          - values.yaml
          values: |
            global:
              mtls:
                enabled: true
              prometheus:
                enabled: false
              logAsJson: true
              actors:
                enabled: false
              ha:
                enabled: false
                replicaCount: 1
              rbac:
                namespaced: true
            dapr_dashboard:
              enabled: false
            dapr_operator:
              watchInterval: 1m
              resources:
                requests:
                  cpu: 100m
                  memory: 100Mi
                limits:
                  cpu: "1"
                  memory: 200Mi
              resources:
                requests:
                  cpu: 100m
                  memory: 30Mi
                limits:
                  cpu: "1"
                  memory: 100Mi
            dapr_sentry:
              resources:
                requests:
                  cpu: 100m
                  memory: 30Mi
                limits:
                  cpu: "1"
                  memory: 100Mi
            dapr_rbac:
              secretReader:
                enabled: false
      syncPolicy:
        automated:
          prune: true
          selfHeal: true
        retry:
          backoff:
            duration: 10s
            factor: 2
            maxDuration: 1m
          limit: 1000
        syncOptions:
    The following table provides further information on replacing the placeholders in the YAML file with adequate values for the respective parameters:
    ParameterPlaceholderDescription
    namespace
    <argo_namespace>
    • Use <argocd> for a dedicated ArgoCD instance.
    • Use <openshift-gitops> for a shared ArgoCD instance.
    namespace
    watchNamespace
    <uipath_namespace>
    Namespace for Automation Suite
    project
    <project_name>
    • For a dedicated ArgoCD instance, use default
    • For a shared ArgoCD instance, use the name of the project created for Automation Suite.
    registry
    repoURL
    <target-registry>
    Helm chart registry
    targetRevision
    <dapr-version>
    Version of the Dapr Helm chart from the versions.json file
    Note:
    If you install Automation Suite in a shared cluster and update the FQDN post-installation, you must delete and recreate the Dapr application by taking the following steps:
    1. In the ArgoCD UI, navigate to Dapr > Delete.
    2. Install Dapr again by following all the steps in this section.
Generating the application YAML file via Bash script
You can also use the following Bash script to generate the application YAML file:
#!/bin/bash
echo "Enter the namespace of argocd applications"
read argocd_namespace
echo "Enter the name of uipath namespace"
read uipath_namespace
if [[ "${argocd_namespace}" == "openshift-gitops" ]]; then
  echo "Enter the argocd project name"
  read project
else
  project="default"
fi
echo "Enter the registry fqdn"
read registry_fqdn
echo "Enter the DAPR helm chart version"
read dapr_version
echo "-------------------- SUMMARY --------------------"
echo "Argocd Application namespace : $argocd_namespace"
echo "Uipath namespace             : $uipath_namespace"
echo "Argocd Project name          : $project"
echo "Helm registry FQDN           : $registry_fqdn"
echo "DAPR Version                 : $dapr_version"
echo "------------- Application yaml file-------------"
echo -n "apiVersion: argoproj.io/v1alpha1
kind: Application
metadata:
  namespace: $argocd_namespace
spec:
  destination:
    namespace: $uipath_namespace
  ignoreDifferences:
  - jsonPointers:
    - /data
    - /stringData
    - /metadata
    kind: Secret
    jsonPointers:
    - /spec/conversion
    jsonPointers:
    - /webhooks
  project: $project
  source:
    chart: helm/dapr
    helm:
      valueFiles:
      - values.yaml
      values: |
        global:
          registry: $registry_fqdn/daprio
          mtls:
            enabled: true
          prometheus:
            enabled: false
          logAsJson: true
          actors:
            enabled: false
          ha:
            enabled: false
            replicaCount: 1
          rbac:
            namespaced: true
        dapr_dashboard:
          enabled: false
        dapr_operator:
          watchInterval: 1m
          resources:
            requests:
              cpu: 100m
              memory: 100Mi
            limits:
              cpu: "1"
              memory: 200Mi
          watchNamespace: $uipath_namespace
          allowedServiceAccounts: $uipath_namespace:default
          resources:
            requests:
              cpu: 100m
              memory: 30Mi
            limits:
              cpu: "1"
              memory: 100Mi
        dapr_sentry:
          resources:
            requests:
              cpu: 100m
              memory: 30Mi
            limits:
              cpu: "1"
              memory: 100Mi
        dapr_rbac:
          secretReader:
            enabled: false
    repoURL: $registry_fqdn
    targetRevision: $dapr_version
  syncPolicy:
    automated:
      prune: true
      selfHeal: true
    retry:
      backoff:
        duration: 10s
        factor: 2
        maxDuration: 1m
      limit: 1000
    syncOptions:
    - RespectIgnoreDifferences=true"#!/bin/bash
  read project
else
  project="default"
fi
read registry_fqdn
read dapr_version
kind: Application
metadata:
spec:
  destination:
  ignoreDifferences:
  - jsonPointers:
    - /data
    - /stringData
    - /metadata
    kind: Secret
    jsonPointers:
    - /spec/conversion
    jsonPointers:
    - /webhooks
  project: $project
  source:
    chart: helm/dapr
    helm:
      valueFiles:
      - values.yaml
      values: |
        global:
          mtls:
            enabled: true
          prometheus:
            enabled: false
          logAsJson: true
          actors:
            enabled: false
          ha:
            enabled: false
            replicaCount: 1
          rbac:
            namespaced: true
        dapr_dashboard:
          enabled: false
        dapr_operator:
          watchInterval: 1m
          resources:
            requests:
              cpu: 100m
              memory: 100Mi
            limits:
              cpu: "1"
              memory: 200Mi
          resources:
            requests:
              cpu: 100m
              memory: 30Mi
            limits:
              cpu: "1"
              memory: 100Mi
        dapr_sentry:
          resources:
            requests:
              cpu: 100m
              memory: 30Mi
            limits:
              cpu: "1"
              memory: 100Mi
        dapr_rbac:
          secretReader:
            enabled: false
  syncPolicy:
    automated:
      prune: true
      selfHeal: true
    retry:
      backoff:
        duration: 10s
        factor: 2
        maxDuration: 1m
      limit: 1000
    syncOptions:
  • Installing cert-manager
  • Installing Dapr
  • Generating the application YAML file via Bash script
