Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
Configuring the FQDN post-installation
To update the FQDN of Automation Suite, you must update the input.json file and run the uipathctl installer.
Note:
Changing the FQDN requires new server certificates. If a new certificate is not available, you have two options: either continue with the new self-signed certificate configured by the installer automatically, or stop the installation and bring in a new CA-issued certificate.
You can configure the certificate via the server_certificate field in the input.json file.
For an Automation Suite installation in a shared cluster, the installer can configure a new certificate automatically only if it has admin privileges in the <istio-system> namespace.
If you update the FQDN post-installation, you must also take the following steps:
Updating the config file with the new FQDN value
You must update the following parameter in the input.json file:
  • fqdn - update this field with new FQDN that you need to access the cluster.
The following example shows the input.json configuration required to update the FQDN.
  "fqdn": "new-automationsuite.mycompany.com" //this is the fqdn for accessing the automation suite cluster
Running the installer for the shared components
To update the FQDN at the shared components level, run the following command:
uipathctl manifest apply input.json --versions version.jsonuipathctl manifest apply input.json --versions version.json
Note:
If you run the command with the --force flag, it will override the warning prompts and perform the FQDN changes directly.
The installer warns you of the consequences of updating the FQDN. It asks for confirmation before proceeding.
[WARN]  You are about to change the FQDN of the Automation Suite Cluster.
        Changing the fqdn is a disruptive operation, and it will result in
        disconnecting your robots, mobile orchestrator users, ML Activities,
        and ML Skills and invalidating any pending user invites.
        If you wish to continue type 'yes' and hit enter to continue.[WARN]  You are about to change the FQDN of the Automation Suite Cluster.
The installer also warns you if there is no new valid certificate related to the FQDN. If the certificate validation fails, the installer requires you to provide the new CA-issued certificate or continue with the new self-signed certificate.
[ERROR] Validating certificate... Failed
[ERROR] Certificate doesn't have new-automationsuite.mycompany.com in the SAN
Certificate provided is invalid for the new fqdn, would you like us to configure the new self signed certificate?
If you wish to continue type `yes` and hit enter to continue.************************************************************************************
Note:
Make sure to clear all the data from your Redis database. You can do this by running the FLUSHALL command.
