- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Configuring appSettings
Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
The Orchestrator configuration consists of an array of Kubernetes config maps and secrets that are loaded in a specific order,
and placed in the
appSettings
section of config maps.
The latest configuration is loaded from the
orchestrator-customconfig
config map. Any newly loaded configuration overwrites all existing settings that have the same key.
To display the current custom Orchestrator configuration, use the
config orchestrator get-config
uipathctl command:uipathctl config orchestrator get-config --app-settings
"key":"value"
"key":"value"
The
uipathctl
commands needed for configuring appSettings
are:
- This exports the current configuration in a key-value pair json file, ready for editing.You can read more about it here.
uipathctl config orchestrator update-config --app-settings appsettings.json
- This updates the configuration with your changes.You can read more about it here.
