- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
- Installation permissions are relevant only if you cannot provide admin privileges to the Automation Suite installer. If you can provide the required admin privileges to the installer, you do not need to follow the instructions in this section.
Automation Suite relies on specific permissions during installation. These permissions are assigned to the service account, which plays a pivotal role in installing the various Automation Suite components.
To configure all the permissions required for installation, take the following steps:
To create a service account, take the following steps:
Create the
<uipath>namespace:kubectl create namespace <uipath>kubectl create namespace <uipath> -
Create a service account named
uipathadmin:kubectl create serviceaccount uipathadmin -n <uipath>kubectl create serviceaccount uipathadmin -n <uipath> -
Use the existing
admincluster role to grant admin permissions to theuipathadminservice account in the<uipath>namespace:kubectl create rolebinding uipathadmin --clusterrole=admin --serviceaccount=<uipath>:uipathadmin -n <uipath>kubectl create rolebinding uipathadmin --clusterrole=admin --serviceaccount=<uipath>:uipathadmin -n <uipath>
uipathadmin service account requires certain permissions during the Automation Suite installation. You provide the necessary permissions
by creating roles. To create each role, save its configuration as a YAML file and run the following command, replacing the
<file_name.yaml> placeholder with the actual name of the YAML file:kubectl apply -f <file_name.yaml>kubectl apply -f <file_name.yaml>You can create the YAML file for each role by copying its corresponding configuration from the following table:
Permissions |
Purpose |
Configuration |
Query the namespace [read-only] |
Required to check whether the namespaces, such as the
<istio-system> namespace, are available or not.
List nodes and CRDs [read-only] |
The prerequisite check and diagnostic health check tool require this permission to perform the node validations, such as the capacity available on the node. | |
Get storage classes [read-only] |
The prerequisite check and diagnostic health check tool require this permission to perform the validations. | |
uipath roles [write]
Most of the Automation Suite installation is performed via ArgoCD; however, the installation of some components is performed via Helm chart. The
uipathctl tool runs an installation job that executes the installation of the Helm chart. Connecting to the kube-api-server and installing the Helm chart in the <uipath> namespace require a namespace-level role-creator role.
<istio-system> roles [write]
Note:
Provide these permissions only if you want the installer to configure the WASM plugin. Otherwise, do not provide the permissions. |
The following operations are performed in the
<istio-system> namespace:
<istio-system> roles [read-only]
Note:
Provide these permissions if you have already configured Istio and installed the WASM plugin. |
uipathadmin service account, by running the following commands:kubectl -n <istio-system> create rolebinding istio-system-automationsuite-rolebinding \
--role=istio-system-automationsuite-role --serviceaccount=<uipath>:uipathadmin
kubectl -n <istio-system> create rolebinding namespace-reader-rolebinding \
--clusterrole=namespace-reader-clusterrole --serviceaccount=<uipath>:uipathadmin
kubectl -n <uipath> create clusterrolebinding list-nodes-and-crd-rolebinding \
--clusterrole=list-nodes-and-crd-clusterrole --serviceaccount=<uipath>:uipathadmin
kubectl -n <uipath> create rolebinding uipath-automationsuite-rolebinding \
--role=uipath-automationsuite-role --serviceaccount=<uipath>:uipathadmin
kubectl -n <uipath> create clusterrolebinding storage-class-reader-binding \
--clusterrole=storage-class-reader --serviceaccount=<uipath>:uipathadmin
## This step is needed only if you want installer to configure the WASM Plugin. Otherwise skip it.
kubectl -n <istio-system> create rolebinding uipadmin-istio-system \
--clusterrole=admin --serviceaccount=<uipath>:uipathadminkubectl -n <istio-system> create rolebinding istio-system-automationsuite-rolebinding \
--clusterrole=admin --serviceaccount=<uipath>:uipathadminkubeconfig file to pass to the uipathctl tool for the installation.
Generating the kubeconfig file on Linux or Mac
kubeconfig file on Linux or Mac, run the following commands:# Create a token
token="$(kubectl -n <uipath> create token uipathadmin --duration=8760h)"
# copy current kubeconfig to a temp file
mkdir temp
cp ~/.kube/config temp/kubeconfig.tmp
# Find the user name and unset it in the temp file
kube_user_name="$(kubectl config view -o jsonpath="{.users[0].name}")"
kubectl -n <uipath> config unset users."${kube_user_name}" --kubeconfig="temp/kubeconfig.tmp"
# Update the credentials in the temp file
kubectl -n <uipath> --kubeconfig="temp/kubeconfig.tmp" config set-credentials uipathadmin --token="$token"
# Set the context and the namespace
kubectl --kubeconfig="temp/kubeconfig.tmp" config set-context --current --namespace=<uipath> --user=uipathadmin
mv temp/kubeconfig.tmp temp/uipathadminkubeconfig# Create a token
mkdir temp
mv temp/kubeconfig.tmp temp/uipathadminkubeconfigkubeconfig file named uipathadminkubeconfig.
Generating the kubeconfig file on Windows
# Create a token
$token = kubectl -n <uipath> create token uipathadmin --duration=8760h
mkdir temp
$kube_user_name = kubectl config view -o jsonpath="{.users[0].name}"
mkdir temp
mv temp/kubeconfig.tmp temp/uipathadminkubeconfigkubeconfig file named uipathadminkubeconfig in the temp folder.
