- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 13, 2025
You must manually create your organizations in Automation Suite. The organization name must comply with the following Regex
format:
'^(?!.*$)[a-zA-Z][A-Za-z0-9]+$'.
The organization name must start with an uppercase or lowercase letter and must contain at least one character after the initial letter. Then, the name can include any combination of alphanumeric characters or underscores. Note, however, that the organization name must not end with an underscore.
For example, valid organization names include
Username, user_name1, or User123. Make sure to avoid invalid formats such as _username (does not start with a letter), username_(ends with an underscore), user name (contains a space), or user@name (contains an invalid character).
Note:
You do not have to manually create the tenant as the migration tool automatically performs this operation for you. The organization and tenant names do not have to be identical. While the organization name is customizable, the Automation Suite tenant name is the same as the standalone Orchestrator tenant name.
