- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
This page walks you through the high-level installation instructions for Automation Suite.
Before you begin, consider the following:
To deploy and manage Automation Suite, you must have knowledge of Kubernetes and cloud resource management. If you encounter issues installing and configuring Automation Suite, contact UiPath® Professional Services.
Before choosing your deployment profile, see Deployment scenarios.
The installation process generates self-signed certificates on your behalf if you grant the installer admin privileges. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. For instructions, see Managing the certificates.
Automation Suite supports enabling Federal Information Processing Standard 140-2 (FIPS 140-2). For details, see Security and compliance.
To check which deployment scenarios are available for Automation Suite, refer to Deployment scenarios.
To install Automation Suite, take the following steps:
