Last updated May 8, 2025
Step 5: Merging organizations in Automation Suite
Migration tool input
When running the UiPath.OrganizationMigrationApp tool, you must provide the following details:
  • The list of organization IDs for the standalone product
  • The list of organization IDs for Automation Suite
For more details, see Migration tool parameters.
Note:
Make sure to use the same organization IDs as the ones identified in Step 1: Moving the Identity organization data from standalone to Automation Suite.
For Linux
Note:
Make sure to follow the general escape instructions for the Shell tool of your choice. For instance, in Bash you must add \ before special characters.
To merge organizations in Automation Suite, run the following command:
./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s '<list of tenant IDs of the standalone product separated by comma, e.g. tenantID1,tenantID2>' -d '<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>'./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s '<list of tenant IDs of the standalone product separated by comma, e.g. tenantID1,tenantID2>' -d '<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>'
Note:
  • Make sure to add TrustServerCertificate=True for both the source and destination SQL connections in the input.
  • If you have multiple organization pairs to merge, make sure the organization ID sequence for the standalone product and the organization ID sequence for Automation Suite match.
  • If you migrate one standalone tenant to one Automation Suite organization for all tenants, you can run the command once for all migrations. However, if you migrate multiple standalone tenants to one Automation Suite organization, you must run the command separately for each tenant, as you may need to resolve user conflicts between the tenants. The following sample shows how to run the command separately for each tenant:
    ./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s 'tenant1' -d 'orgId1'
    ./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s 'tenant2' -d 'orgId1'
    ./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s 'tenant3' -d 'orgId1'./UiPath.OrganizationMigrationApp merge -i '<identity database connection of Automation Suite>' -o '<restored orchestrator DB in Automation Suite connection string>' -s 'tenant1' -d 'orgId1'
For instructions on how to address user conflicts when migrating multiple standalone tenants to a single Automation Suite organization, see .
For Windows
./UiPath.OrganizationMigrationApp merge -i "<identity database connection of Automation Suite>" -o "<restored orchestrator DB in Automation Suite connection string>" -s "<list of tenant IDs of the standalone product separated by comma, e.g. tenantID1,tenantID2>" -d "<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>"./UiPath.OrganizationMigrationApp merge -i "<identity database connection of Automation Suite>" -o "<restored orchestrator DB in Automation Suite connection string>" -s "<list of tenant IDs of the standalone product separated by comma, e.g. tenantID1,tenantID2>" -d "<list of organization IDs of Automation Suite separated by comma, e.g. orgID1,orgID2>"
Note:
  • Make sure to add TrustServerCertificate=True for both source and destination SQL connection strings in the input.
For instructions on how to address user conflicts when migrating multiple standalone product tenants to a single Automation Suite organization, see .
Merge expectations
Users
Note:
Only users that are originally from standalone Orchestrator have access to Orchestrator after migrating to Automation Suite.
The following table provides insight into multiple migration scenarios and how they impact users:
Condition
Does the source user have an email address?
Does the target user have an email address?
Is the source user email the same as the one of the target user?
Is the source username the same as the target username?
Result
1
available
available
not available
not available
The source user is moved to the target organization; the target organization user has access to standalone Orchestrator.
2
available
available
not available
available
After the merge, two users have the same username, and they must use the email address to login.
3
available
available
available
available or not available
The source user is merged with the target user; the target user has access to standalone Orchestrator.
4
not available
not available
N/A
not available
5
not available
not available
N/A
available
6
available
not available
N/A
not available
7
available
not available
N/A
available
You must manually configure the email address for the target user or remove the target user.
If you configure the email address, the source user is merged with the target user, and the target user has access to standalone Orchestrator.
If you remove the target user, the source user is moved to the target organization, and the target organization user has access to standalone Orchestrator.
8
not available
available
N/A
not available
The source user is moved to the target organization, and the target organization user has access to standalone Orchestrator.
9
not available
available
N/A
available
You must configure the email address to be empty for the target user or remove the target user.
If you configure the email address as empty, the source user is merged with the target user, and the target user has access to standalone Orchestrator.
Robot users
If the source and target robot usernames are the same, the source robot user is appended the user ID and is move to the target organization.
Source robot username
Target robot username
Moved source robot username
sameRobot
sameRobot
sameRobot_47a26d4a-2180-4fdd-8e1e-2379300a1162
Groups
If the source and target robot group names are the same, the source robot user is appended a string and is moved to the target organization.
Source group name
Target group name
Moved source group username
sameGroup
sameGroup
sameGroup_db39a5c6-f73c-4011-b40e-4ea620fe3d01
Settings
If source settings and target settings have the same name, the setting value of the target is used.
If organization merge failed
If the organization merge failed, check the logs. Depending on whether the Identity or the Orchestrator migration failed, take the following steps:
Failed Identity migration
If the Identity migration failed, you can just fix the error and execute the organization merge command again. This would rollback all the changes since we have set a transaction for operations for Identity.
Failed Orchestrator migration
If the Orchestrator migration failed, the Orchestrator database would roll back, but the Identity database would not rollback. As a result, you must restore the backup of the Identity database and replace the connection string to use the new database. After fixing the error, run organization merge command again.
If the Orchestrator migration failed, take the following steps:
  1. Restore the backup of the Identity database.
    1. Right-click the database directory and select Import Data-tier Application.
      docs image
    2. Select the backup database file.
      docs image
    3. Input the backup database name.
      docs image
    4. Wait for the process to complete.
      docs image
  2. Replace the identity connection string.
    `"platform": {
        "sql_connection_str": "<dotnet connection string>",   (added line)
        "enabled": true,
    },``"platform": {
        "enabled": true,
  3. Fix the error and use the new platform connection string to run the merge command again.
