- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Running uipathctl
- Prerequisite checks
- Output example: prerequisite check
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Prerequisite checks
It is recommended to run prerequisite checks to ensure that you properly configured the cloud infrastructure and to validate input.json before starting the Automation Suite installation.
You can run a prerequisite check using the command. By default, this command verifies all the prerequisites. You can use the following flags:
--excluded, if you want to exclude components from the execution.--verbose, if you want to access the detailed prerequisites check output. You can skip this flag for a more concise and simplified output.
The prerequisite and health checks/tests run in the <uipath> namespace. You must either grant the uipathctl tool the necessary permissions to allow the creation of the <uipath> namespace or create it yourself before running the checks/tests. Additionally, some checks/tests require that you enable the use of hostNetwork.
The checks in the following table are run on each node:
| Check | Description |
| SQL Connection | Validates that Automation Suite can successfully connect to the SQL server for UiPath® products and shared services (such as Identity, Portal, Org Mamagement, etc.) using the SQL connection strings provided in the input.json file. This is mandatory for a successful installation. |
| SQL DB roles | Validates the necessary roles and permissions required by UiPath® products. This is mandatory for a successful installation. |
| SQL DB compatibility | Validates SQL DB compatibility requirements. |
| FQDN resolution | Validates that the FQDN and the sub-domains are successfully resolvable. |
| Object Storage API | Validates that objectstore APIs are accessible based on access information provided in the input.json file. This is mandatory for a successful installation of the UiPath® services. |
| Cache / Redis | Validates the connection to Cloud Redis or ElastiCache. This is mandatory for a successful installation. |
| Capacity | Validates you have minimum CPU and RAM capacity on the worker nodes based on the products enabled in the input.json file. |
| Storage Class | Validates that the storage classes for File Storage are configured as required for Automation Suite Robots. |
| Optional Components | Validates that your cluster has components that you chose to exclude from the Automation Suite installation. |
| Ingress | Validates that the cluster ingress is configured correctly and the FQDN URL requests can reach UiPath® products. |
| Network Policies | Checks if the network policies configured in Automation Suite are compatible with the cluster. |
| Registry | Validates that Automation Suite can access the UiPath® docker registry. This is mandatory for a successful installation. |
| Cluster Connectivity | Validates whether the cluster communication is configured properly:
| Queues | Validates that queue APIs are accessible based on access information provided in input.json and that the required queues exist. This is mandatory for a successful installation. |
