- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Performing Insights database maintenance
- Configuring log rules
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
dbo and read. Both tables store data from Orchestrator databases and pass data between each other. Over time, tables store a large amount
of data that can impact database performance. You can free up space by removing data that is not relevant or outdated.
The estimated threshold for storing historical data is set to
- Up to 100 million jobs
- Up to 1 billion job events
- Up to 100 million queue items
- Up to 500 million queue item events
- Up to 1 billion robot logs
[dbo].Jobs, [dbo].JobEvents, [dbo].QueueItems, [dbo].QueueItemEvents, [dbo].RobotLogs tables, or just the [dbo].RobotLogs.
PROCEDURE
[read].[Delete_Insights_Data_Read] and PROCEDURE
[read].[Delete_Process_Logs_Read] scripts, the Insights module needs to be
disabled.
- Scripts with the
_DBOsuffix are used to delete data from DBO schema tables, - Scripts with the
_Readsuffix are used to delete data from Read schema tables. - Large-sized batches might impact the speed of execution. Consider using the default batch size, which is set to 100000.
PROCEDURE [read].[Delete_Insights_Data_Read] and
PROCEDURE [read].[Delete_Process_Logs_Read] scripts, the Insights module
needs to be disabled.
Jobs, JobEvents, QueueItems, QueueItemEvents, RobotLogs) for a cut-off timestamp.
| SQL Stored Procedures | Parameter | Description |
| Delete_Insights_Data_DBO |
| Delete data from [dbo].[Jobs],
[dbo].[JobEvents], [dbo].[QueueItems], [dbo].[QueueItemEvents], [dbo].[RobotLogs] tables based on a cut-off timestamp.
| Delete_Insights_Data_Read | N/A | Truncate [read].Jobs, [read].JobEvents,[read].QueueItems, [read].QueueItemEvents, [read].RobotLogs tables.
The Insights Dashboard widgets are available again after SQL Stored Procedure 1 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
Delete_Insights_Data_DBO SQL Script, it creates a QueueItems.IX_CreationTime nonclustered index with the purpose of making future executions faster.
Generate and save this SQL Stored Procedure to delete RobotsLogs based on ProcessNames and Tenant ID.
| Delete_Process_Logs_DBO |
The Orchestrator process name.
Tenant ID is required as two tenants might run processes with identical names.
Delete data in batches of 100000. See Considerations. | Delete data from [dbo].[RobotLogs] table by ProcessName and Tenant ID.
| Delete_Process_Logs_Read |
| Truncate [read].RobotLogs table.
