- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 13, 2025
If you encounter issues while installing or configuring Automation Suite, refer to the following:
