- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- [Preview] Generating the configuration file using a wizard
- AKS input.json example
- EKS input.json example
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
The following an example shows an input.json
file with all the products enabled, as well as the mandatory and optional configuration parameters for Automation Suite on
AKS. You can use the example as reference and make changes according to your environment requirements.
Note that the minimum UiPath® product selection requires the platform services to be enabled. Make sure to replace FQDNs, hostnames, usernames and passwords, and SQL connection strings with your own configurations.
"registries": {
"docker": {
"url": "registry.uipath.com"
"helm": {
"fqdn": "ci-asaks4002399.devtest-sl-ea.infra.uipath-dev.com",
"profile": "ha",
"fabric": {
"redis": {
"hostname": "ci-asaks4002399.redis.cache.windows.net",
"password": "REDIS_PASSWORD_PLACEHOLDER",
"port": 6380,
"tls": true
"external_object_storage": {
"enabled": true,
"storage_type": "azure",
"account_key": "----",
"account_name": "----",
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"azure_fqdn_suffix": "core.windows.net",
"use_managed_identity": false
"use_workload_identity": true
"pod_identity" : {
"enabled": true,
"aks_managed_identity_client_id": <client-id>,
"kubernetes_distribution": "aks",
"sql_connection_string_template": "Server=tcp:ci-asaks4002399.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=mssqladminun@ci-asaks4002399.database.windows.net;Password='SQL_PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://ci-asaks4002399.database.windows.net;database=DB_NAME_PLACEHOLDER;user=mssqladminun@ci-asaks4002399.database.windows.net;password={SQL_PASSWORD_PLACEHOLDER};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
"sql_connection_string_template_odbc": "SERVER=ci-asaks4002399.database.windows.net;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=mssqladminun;PWD={SQL_PASSWORD_PLACEHOLDER};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=ci-asaks4002399.database.windows.net",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://mssqladminun%40ci-asaks4002399.database.windows.net:SQL_PASSWORD_PLACEHOLDER@ci-asaks4002399.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
"admin_username": "admin",
"admin_password": "----",
"dataservice": {
"enabled": true,
"bucket_name": "uipath-as-dataservice"
"orchestrator": {
"enabled": true,
"bucket_name": "uipath-as-orchestrator"
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"bucket_name": "uipath-as-processmining"
"enabled": true
"integrationservices": {
"enabled": true,
"bucket_name": "uipath-as-platform"
"studioweb": {
"enabled": true,
"insights": {
"enabled": true,
"task_mining": {
"bucket_name": "uipath-as-taskmining"
"enabled": true
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache",
"enabled": true
"storage_class": "managed-premium",
"storage_class_single_replica": "azurefile-csi",
"infra": {
"docker_registry": {}
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/azure-load-balancer-internal": "true"
"istioMinProtocolVersion": "TLSV1_3",
"snapshot": {
"enabled": true,
"aks_infra_resource_group": "MC_ci-asaks4002399_ci-asaks4002399_eastus",
"cloud_name": "AzurePublicCloud",
"resource_group": "ci-asaks4002399",
"auth_mode": "ServicePrincipal",
"subscription_id": "b65b0225-ce9b-4a79-9dd9-c00071d40d64",
"tenant_id": "d8353d2a-b153-4d17-8827-902c51f72357",
"account_name": "storaccid2547865",
"bucket_name": "uipath-backup",
"client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e",
"client_secret": "----"
"platform": {
"enabled": true
"registries": {
"docker": {
"helm": {
"profile": "ha",
"fabric": {
"redis": {
"port": 6380,
"tls": true
"enabled": true,
"pod_identity" : {
"enabled": true,
"dataservice": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"enabled": true
"enabled": true,
"studioweb": {
"enabled": true,
"insights": {
"enabled": true,
"task_mining": {
"enabled": true
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"enabled": true
"infra": {
"ingress": {
"snapshot": {
"enabled": true,
"platform": {
"enabled": true
