- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Known issue and resolution for pods stuck in the uipath namespace when custom node taints are enabled in Automation Suite on EKS.
Pods in the <uipath> namespace are not running when custom node taints are enabled. The pods cannot talk to the adminctl webhook that injects pod tolerations in an EKS env.
Solution
To fix the issue, create a network policy to allow traffic into the admctl webhook from the cluster CIDR or 0.0.0.0/0.
kind: NetworkPolicy
apiVersion: networking.k8s.io/v1
metadata:
namespace: <uipath>
spec:
podSelector:
matchLabels:
app: admctl-webhook
ingress:
- ipBlock:
cidr: <cluster-pod-cdr> or "0.0.0.0/0"
kind: NetworkPolicy
metadata:
namespace: <uipath>
spec:
podSelector:
matchLabels:
app: admctl-webhook
ingress:
- ipBlock:
