- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 6, 2025
When attempting to run a scheduled backup in Automation Suite on EKS/AKS, Velero may return the following error:
Phase: FailedValidation
Validation errors: an existing backup storage location was not specified at backup creation time and the server default default does not exist.
Error: BackupStorageLocation.velero.io "default" not foundPhase: FailedValidation
This occurs due to the
default-bs1 BackupStorageLocation not being marked as default in the Velero configuration.
To address the issue, take the following steps:
