- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- AI Center provisioning failure after upgrading to 2023.10 or later
- Insights volumes created in two different zones following migration
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Resolve Automation Hub access loss after upgrading to Automation Suite 2024.10.0 on EKS/AKS by running a corrective SQL script.
Following an upgrade to Automation Suite 2024.10.0, you can no longer access Automation Hub. The issue does not affect Automation Suite 2024.10.1 and later versions.
Solution
To address the problem, you must run the following SQL script on the AutomationSuite_Automation_Hub database:
-- IMPORTANT:
-- This script should be executed in the AutomationSuite_Automation_Hub database.
-- Purpose:
-- This script resolves potential issues encountered during the upgrade to version 2024.10.0 of Automation Hub.
-- Please replace placeholders with actual data before running the script.
-- Assumptions:
-- The customer has an existing Automation Hub instance running a version prior to 2024.10.0.
-- Variables:
-- @AccountName: Logical name of the Automation Suite organization. Replace '<USER_INPUT>' with the actual name.
-- @TenantName: Logical name of the Automation Suite tenant. Replace '<USER_INPUT>' with the actual name.
-- Note:
-- The script will terminate if any errors occur and will provide error details for debugging.
SET XACT_ABORT ON;
-- Replace placeholders with actual values
DECLARE @AccountName NVARCHAR(255) = '<USER_INPUT>';
DECLARE @TenantName NVARCHAR(255) = '<USER_INPUT>';
-- DO NOT EDIT ANYTHING AFTER THIS POINT --
BEGIN TRY
BEGIN TRANSACTION;
-- Validate placeholders
IF @AccountName = '<USER_INPUT>' OR
@TenantName = '<USER_INPUT>'
BEGIN
RAISERROR('Placeholders were not replaced with actual values. Please update the script and retry.', 16, 1);
RETURN;
END;
-- Declare variables for tenant information
DECLARE @TenantUUID NVARCHAR(255);
DECLARE @TsTablePrefix NVARCHAR(255);
-- Retrieve tenant_uuid from the cloud_tenants table based on TenantName and AccountName
DECLARE @sql NVARCHAR(MAX);
DECLARE @params NVARCHAR(MAX);
SET @sql = N'SELECT @TenantUUID = tenant_uuid
FROM ah.cloud_tenants
WHERE cloud_TenantName = @TenantName
AND cloud_AccountName = @AccountName;';
SET @params = N'@TenantName NVARCHAR(255), @AccountName NVARCHAR(255), @TenantUUID NVARCHAR(255) OUTPUT';
EXEC sp_executesql @sql,
@params,
@TenantName = @TenantName,
@AccountName = @AccountName,
@TenantUUID = @TenantUUID OUTPUT;
-- Abort if tenant_uuid is not found
IF @TenantUUID IS NULL
BEGIN
RAISERROR('No tenant found for the provided TenantName and AccountName. Script execution aborted.', 16, 1);
RETURN;
END;
-- Retrieve tenant_db_table_prefix from tenants table using tenant_uuid
SET @sql = N'SELECT @TsTablePrefix = tenant_db_table_prefix
FROM ah.tenants
WHERE tenant_uuid = @TenantUUID;';
SET @params = N'@TenantUUID NVARCHAR(255), @TsTablePrefix NVARCHAR(255) OUTPUT';
@params,
@TenantUUID = @TenantUUID,
@TsTablePrefix = @TsTablePrefix OUTPUT;
-- Abort if tenant_db_table_prefix is not found
IF @TsTablePrefix IS NULL
BEGIN
RAISERROR('No tenant found in the tenants table for the provided tenant_uuid. Script execution aborted.', 16, 1);
RETURN;
END;
-- Drop the default constraint for assignment_days column
DECLARE @ConstraintName NVARCHAR(200);
SELECT @ConstraintName = dc.name
FROM sys.default_constraints dc
INNER JOIN sys.columns c
ON dc.parent_object_id = c.object_id
AND dc.parent_column_id = c.column_id
WHERE c.object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
AND c.name = 'assignment_days';
IF @ConstraintName IS NOT NULL
BEGIN
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates DROP CONSTRAINT [' + @ConstraintName + ']');
END;
-- Recreate the default constraint for assignment_days
DECLARE @UniqueConstraintName NVARCHAR(255) = '[' + @TsTablePrefix + 'DF_assignment_days]';
BEGIN
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ADD CONSTRAINT ' + @UniqueConstraintName + ' DEFAULT 0.00 FOR assignment_days');
END
-- Drop the index on the assignment_days column
IF EXISTS (SELECT 1
FROM sys.indexes
WHERE name = 'assignment_days'
AND object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
BEGIN
EXEC('DROP INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates');
END;
-- Alter the assignment_days column
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ALTER COLUMN assignment_days NUMERIC(15, 2) NOT NULL');
-- Recreate the index on assignment_days
EXEC('CREATE NONCLUSTERED INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates (assignment_days ASC)');
-- Insert a record into the migrations table
EXEC('INSERT INTO ' + @TsTablePrefix + 'migrations (name, run_on) VALUES (''tenants/20230925145641-edit-cba-one-time-costs-estimates-table-column'', CURRENT_TIMESTAMP)');
-- Commit the transaction
COMMIT TRANSACTION;
PRINT 'Script executed successfully.';
END TRY
BEGIN CATCH
IF @@TRANCOUNT > 0
ROLLBACK TRANSACTION;
-- Output error details
PRINT 'Error occurred during script execution:';
PRINT 'Error Number: ' + CAST(ERROR_NUMBER() AS VARCHAR(10));
PRINT 'Error Severity: ' + CAST(ERROR_SEVERITY() AS VARCHAR(10));
PRINT 'Error State: ' + CAST(ERROR_STATE() AS VARCHAR(10));
PRINT 'Error Procedure: ' + ISNULL(ERROR_PROCEDURE(), '');
PRINT 'Error Line: ' + CAST(ERROR_LINE() AS VARCHAR(10));
PRINT 'Error Message: ' + ERROR_MESSAGE();
END CATCH;
-- IMPORTANT:
-- Purpose:
-- Assumptions:
-- Variables:
-- Note:
SET XACT_ABORT ON;
BEGIN TRY
BEGIN TRANSACTION;
BEGIN
RETURN;
END;
@params,
BEGIN
RETURN;
END;
FROM ah.tenants
@params,
BEGIN
RETURN;
END;
BEGIN
END;
BEGIN
END
IF EXISTS (SELECT 1
FROM sys.indexes
BEGIN
END;
COMMIT TRANSACTION;
END TRY
BEGIN CATCH
IF @@TRANCOUNT > 0
END CATCH;
