- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Applying miscellaneous configurations
Automation Suite on EKS/AKS Installation Guide
Last updated Dec 18, 2024
Note: Only apply the configurations in this section if you cannot provide admin privileges to the Automation Suite installer. If
you can provide the required permissions to the installer, you do not need to apply the configurations in this section.
To create a priority class for UiPath® applications, take the following steps:
To create namespace labels, run the following commands:
kubectl label namespace <uipath> uipath-injection=enabled
kubectl label namespace <uipath> istio-injection=enabled
