Last updated Nov 6, 2025
Compatibility matrix
Azure third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on AKS.
Prerequisites for Azure
Compatible versions
Azure Kubernetes Service (AKS)
Architecture
x86
Ubuntu
22.04
Cloud Redis
Version 6
Microsoft SQL Server
Microsoft SQL Server 2016, 2017, 2019, and 2022, Standard and Enterprise editions. For product-specific version dependency, see SQL database.
PostgreSQL
Note:
Process Mining on Automation Suite 2024.10.3 or higher.
PostgreSQL 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
Prometheus (if you bring your own)
3.5.0
Grafana (if you bring your own)
12.0.2
Alert Manager (if you bring your own)
0.28.1
FluentD/Fluent-bit (if you bring your own)
helm-charts: logging-operator, logging-operator-logging
6.0.1
Gatekeeper (if you bring your own)
helm-charts: gatekeeper
3.20.0
Velero (if you bring your own)
helm-charts: velero
10.0.10
Cert Manager (if you bring your own)
helm-charts: cert-manager
1.18.2
Istio (if you bring your own)
helm-charts: istio-base
1.26.3
AWS third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on EKS.
Prerequisites for AWS
Compatible versions
Elastic Kubernetes Service (EKS)
Architecture
x86
RHEL
8.8 for EKS 1.33
Amazon Linux
AL2 and AL2023 for all EKS versions except EKS 1.33 where only AL2023 is supported
Bottlerocket
1.19.2
Elasticache
version 6.2.6
Database - RDS
15.00.4236.7.v1
3.5.0
12.0.2
0.28.1
6.0.1
3.20.0
helm-charts: velero
10.0.10
1.18.2
1.26.3
Kubernetes compatibility
Note:
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and a Kubernetes version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the Kubernetes support calendar, see the Kubernetes documentation.
Updating your Kubernetes cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2024.10.0, the last supported version for your cluster is Kubernetes 1.30. When this version reaches its end of life, you must update your cluster to a newer Kubernetes version. This also requires updating to a newer Automation Suite CU.
The following table lists the Kubernetes versions validated and supported with each Automation Suite 2024.10.x CU.
Compatible Kubernetes versions
2024.10.61.31, 1.32 , 1.33
2024.10.51.31, 1.32 , 1.33
2024.10.41.30 , 1.31, 1.32
2024.10.3
1.30 , 1.31, 1.32
2024.10.2
1.29, 1.30 , 1.31
2024.10.1
1.28, 1.29 , 1.30
2024.10.0
1.28, 1.29 , 1.30
