- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Step 1: Removing old cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Validating the Insights migration
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
To clean up the Redis keys for Orchestrator and Identity, take the following steps:
- For Orchestrator, navigate to the cloud-based Redis console and run the following command:
FLUSHDBFLUSHDB - For Identity, navigate to the cloud-based Redis console and run the following command:
SELECT 1 FLUSHDBSELECT 1 FLUSHDB
