- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Last updated Nov 6, 2025
Accessing an FQDN may return the following error:
RBAC: access deniedRBAC: access denied
This issue occurs because the FQDN and its relevant URL access are routed via Istio. Istio relies on a WASM plugin to route the request to the appropriate destination pod.
If the WASM plugin image is missing in the registry, internal or external, Istio blocks the URL access and returns a
RBAC: access denied error.
To address this issue, you must ensure that the registry is hydrated and the WASM plugin image exists in registry.
To check the WASM plugin image, run teh folowing command:
kubectl get wasmplugin -A -o yaml | grep urlkubectl get wasmplugin -A -o yaml | grep url
url: oci://testing.azurecr.io/istio-wasm-plugin:2024.10.3url: oci://testing.azurecr.io/istio-wasm-plugin:2024.10.3
istio-wasm-plugin:2024.10.3. You must check if this image is present in your registry or not.
