- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Automation Suite on EKS/AKS Installation Guide
Backing up the cluster
There is a known issue with the backup logic in Automation Suite for AKS/EKS. Specifically, this defect excludes the backup of Insights dashboards. However, all historical data is successfully backed up.
We are working diligently to resolve this issue. We aim to develop and implement a mitigation approach as early as possible.
If you are using Automation Suite on AKS/EKS along with UiPath Insights, this defect may affect your operations. While we address this issue, we suggest manually exporting your dashboards as a preventive measure.
Note that backups are mainly used as a recovery method in the event of a disaster-level incident or in preparation for an Automation Suite upgrade. This is essential if an upgrade fails and stored data needs to be restored to its previous state.
Before taking a backup, you must provide the objectstore configuration to store the backup. For this, see Configuring the backup store.
--schedule
and --retention
flags. By default, Automation Suite takes a backup every 45 minutes after starting and retains the last seven days of snapshots.
To enable the backup at the scheduled time, run the following command:
./uipathctl snapshot backup enable --schedule "*/45 * * * *" --retention 168h --prefix "mysnapshot"
Running this command ensure that backups are taken in scheduled time intervals.
Flag |
Description |
UNIX cron expression for schedule. This is only required if you want to enable a schedule backup. Default value is
"*/45 * * * *" , which means a backup is taken every 45 minutes.
Retention policy in the following duration format:
Hh:Mm:Ss . For example, 8h5m1s .
This will prefix the snapshot backups' names with the given string. This is only used if you want to enable a scheduled backup. The default value is a
snapshot. |
--schedule
parameter matches the time of the cluster node. We recommend syncing the cron expression with the scheduled backup of your
external data stores (such as SQL database and objectstore).
Note 2: Automation Suite stores only the snapshot backed up during the defined retention policy. If your retention policy has a shorter duration, you may lose essential snapshots once the retention policy applies. Similarly, if the retention policy is longer, more snapshots are stored, which may take up space on your objectstore.
Note 3: Carefully consider the schedule setup. Taking snapshots at small intervals (for example, every 30 minutes) implies frequent backup operations, forcing you to store the last 30 minutes' data. Similarly, taking snapshots once a week can cause data loss if a disaster occurs much later than the previous backup. Therefore, we strongly recommend synchronizing the backup schedule and the retention duration with your Recovery Point Objective (RPO) requirements.
To disable the scheduled backup, run the following command:
./uipathctl snapshot backup disable --prefix <prefix_name>
--prefix
parameter; however, if you did not configure any prefix while allowing the backup, provide a snapshot
as a prefix value.
To take an on-demand snapshot backup, run the following command:
./uipathctl snapshot backup create <snapshot_name>
The aforementioned command takes an optional flag:
Flag |
Description |
Wait until the backup completes |
--wait
command, the command executes in the background. To view the status of your backup, check the snapshot list as described
in the following section.
To list all the present snapshots, their status, and the time at which they were taken, run the following command:
./uipathctl snapshot list
Sample output:
NAME STATUS CREATION EXPIRATION
manualbackup1 Completed 2022-09-13 09:19:50 +0000 UTC 2023-09-13 09:19:50 +0000 UTC
manualbackup2 PartiallyFailed 2022-09-13 09:19:50 +0000 UTC 2023-09-13 09:19:50 +0000 UTC
Deleting a backup consists of deleting the cluster metadata and the volume data from the backup storage server. This operation is irreversible.
To delete the snapshot backups from the backup store, run the following command:
./uipathctl snapshot delete <snapshot_name>
You can retrieve the name of the snapshot that you want to delete by running the snapshot list command.
The command takes the following additional parameters:
Flag |
Description |
Delete all snapshots. If selecting this option, then you do not need to provide the name of the snapshot. |
Forcibly delete the snapshot without confirmation. |
