Last updated May 15, 2026
Disaster recovery - Active/Passive
This article walks you through the core concepts and architecture of Automation Suite disaster recovery, covering Active/Passive deployments.
Important:
Active/Passive mode is currently available only for EKS.
Ensuring continuous business automation is at the core of any automation platform. Automation Suite can withstand the complete failure of nodes, entire data centers, or regions. You can deploy Automation Suite as an Active/Passive configuration.
Automation Suite multi-site deployments in Active/Passive mode support the following scenarios:
  • Same-region deployment - Two Automation Suite clusters deployed in the same region;
  • Cross-region deployment - Two Automation Suite clusters deployed in different regions.
The following table provides details on which Automation Suite products you can deploy in Active/Passive mode.
ProductSupport for Active/Passive
Orchestrator
Action Center
AI Center
Apps
Automation Ops
Automation Suite Robots
Computer Vision
Data Service
Document Understanding
Test Manager
Automation Hub
Insights
Process Mining
Task Mining
Integration Service
Studio Web
Note:
  • You can install products that are not supported in Disaster Recovery with Active/Passive . However, you cannot use these products when the primary cluster is down.
  • For AI Center, the training pipeline functionality is available only in the primary cluster.
Requirements
To configure an Active/Passive deployment, make sure you meet the following requirements:
  • Hardware
  • Database
  • Amazon Elastic Cache (Redis)
  • S3 (Object Store)
  • SQS (Queues)
  • Route 53
Hardware
The secondary (Passive) hardware cluster must be identical to the Primary hardware cluster.
Database
The database must be accessible from both the Active and Passive clusters.
The system must operate separately for both the Active cluster and the Passive cluster.
S3 (Object Store)
The S3 system must be synchronized and it must support Cross-Region Replication (CRR).
SQS (Queues)
SQS must operate separately on Active and Passive setups.
Route 53
Route53 must be used to control the routing of traffic. Configuration in Route53 is required to direct traffic to the active load balancer when functional.
In case of a disaster, the traffic must be re-routed to the passive load balancer using route 53.
  • Requirements
  • Hardware
  • Database
  • S3 (Object Store)
  • SQS (Queues)
  • Route 53
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
