- Overview
- Requirements
- Prerequisite checks
- uipathctl cluster
- uipathctl cluster upgrade
- uipathctl config
- uipathctl config alerts
- uipathctl health
- uipathctl health bundle
- uipathctl health check
- uipathctl health diagnose
- uipathctl health test
- uipathctl identity
- uipathctl identity add-host-admin
- uipathctl identity enable-basic-auth
- uipathctl manifest
- uipathctl manifest apply
- uipathctl manifest diff
- uipathctl manifest get
- uipathctl manifest render
- uipathctl prereq
- uipathctl prereq create
- uipathctl prereq run
- uipathctl resource
- uipathctl resource report
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- uipathctl sso
- uipathctl sso generate-connector
- uipathctl sso generate-overlays
- uipathctl sso generate-rbac
- uipathctl version
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
![](https://docs.uipath.com/_next/static/media/grid.05ebd128.png?w=3840&%3Bq=100)
Automation Suite on EKS/AKS Installation Guide
Last updated Sep 5, 2024
Change the Orchestrator custom configuration.
uipathctl config orchestrator [flags]
