- Overview
- UI Automation
- About the UI Automation activity package
- Applications and technologies automated with UI Automation
- Project compatibility
- UI Automation Classic Project Settings
- UI Automation Modern Project Settings
- UI Automation Project Settings
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Accessibility Check
- Application Event Trigger
- Block User Input
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Extract Table Data
- Find Elements
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Save Image
- Select Item
- Set Browser Data
- Set Clipboard
- Set Runtime Browser
- Set Focus
- Set Text
- Take Screenshot
- Type Into
- Unblock User Input
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Terminal
- Release notes
- About the Terminal activity package
- Best practices
- Find Text
- Get Color at Position
- Get Cursor Position
- Get Field
- Get Field at Position
- Get Screen Area
- Get Text
- Get Text at Position
- Move Cursor
- Move Cursor to Text
- Send Control Key
- Send Keys
- Send Keys Secure
- Set Field
- Set Field at Position
- Terminal Session
- Wait Field Text
- Wait Screen Ready
- Wait Screen Text
- Wait Text at Position
- Terminal coded automation APIs
UI Automation activities
These project settings apply for Modern activities in Windows - Legacy, and Windows projects.
Use Project Settings to configure changes at the project level. These global settings impact all activities in the package that have the properties listed below. For more information, see Configuring Activity Project Settings.
The properties configured in Project Settings only take effect in the activities of the workflow if their properties have not been edited. Editing properties manually no longer applies the project settings to them.
To configure the UI Automation Modern project settings, follow these steps:
- In the Project panel, go to Project Settings.
- Navigate to Activities Settings > UI Automation Modern.
- Modify the settings according to what you want to change.
- Click OK to save changes.
You can reset all settings to their default values or copy all values between the debug and production fields using the Bulk Actions drop-down menu at the top of the window.
Generic
The settings below apply to UI Automation Modern activities in Windows - Legacy, and Windows projects that have either one of the following properties.
| Property name | Description |
| Delay after (seconds) | Delay time between the current activity and the next activity. |
| Delay before (seconds) | Delay time between the previous activity and the current activity. |
| Timeout (seconds) | How long to wait for the current activity to be executed before throwing an error. |
| Wait for page load | Before performing the action, wait for the application to become ready to accept input. The following options are available:
| Capture screenshots | Dictates if screenshots are captured at design time by all the activities that support this feature. If the setting is set to false, the Remove informative screenshot option from the context menu is disabled. |
| Show closest matches in the 'Element not found' error message | If set to True , ten suggestions of the closest selector matches that can be used to replace the faulty selectors are displayed in the logs. |
| Alter disabled element | If set to True , the Select Item action is executed even if the specified UI element is disabled. This property does not apply if the Input Mode property is set to Hardware Events . |
| Wait for primary targeting method until timeout | If set to True , this setting allows the primary targeting method to consume its full timeout until any fallback targeting method can be used. |
| Ask user on runtime error | If set to True , a prompt is displayed allowing you to decide what to do next and continue the automation instead of just stopping the execution. |
| Automatically add UI elements to Object Repository | If set to True , all UI elements are automatically added to Object Repository. |
Targeting methods - Desktop applications
The settings below apply to indicated targets and anchors for desktop applications.
| Input mode | Select how to execute the action:
| Selector - default find type | Select the default type of find used by the UI element selector. The following options are available:
| Computer Vision | If set to True, uses the Computer Vision method. The default value is False.
Note: The default value of this project setting was True in Studio projects created with UiPath.UIAutomation.Activities dependency versions earlier than 25.10.27, 24.10.17, or 23.10.20. |
| Image | If set to True , uses the Image targeting method. Note: This method is only used for the Check App State activity if the other methods are disabled. |
| Generate native WPF selectors (Preview) | Enable the generation of native WPF selectors for WPF applications. |
Targeting methods - Web browsers
The settings below apply to indicated targets and anchors for web applications.
| Input mode for Edge, Chrome | Select how to execute the action:
| Input mode for Firefox, IE, Edge in IE Mode | Select how to execute the action:
Targeting methods - Java
The settings below apply to indicated targets and anchors for Java applications.
Targeting methods - SAP
The settings below apply to indicated targets and anchors for SAP.
| Computer Vision | If set to True, uses the Computer Vision method. The default value is False. |
Verify execution
Settings for all the activities that have the Verify Execution feature.
| Timeout (seconds) | The amount of time (in seconds) to wait for the verification element to appear/disappear. If Retry is set to True , the action is performed again, followed by the verification, for the duration specified in the Timeout property. |
| Retry | If set to True, the action is retried for the duration of the activity timeout, if the expected outcome was not achieved. By default, this check box is selected. |
| Always auto-verify typed text | If set to True, any action that types text is verified using the Verify Execution feature. |
Application/Browser
The settings below apply to the Use Application/Browser activity.
| Open | Defines whether to open the target application before executing activities in it. The following options are available:
| Close | Defines whether to close the target application after executing activities in it. The following options are available:
| Window attach mode | Specifies the default window attach mode used by newly added Use Application/Browser activities. The following options are available:
| Resize window | Defines whether the application/browser is resized when initialized.
| Runtime browser | Specifies which browser you want to use at runtime. The following options are available:
| WebDriver Mode | Indicates how the WebDriver is used when opening a new browser session. The following options are available:
| Automatically download WebDriver | If set to True , specifies whether you want to automatically download the required WebDriver executable version. |
| User data folder mode | The user data folder mode you want to set. It is used to start the browser with a specific user data folder.
| User data folder path | The path to the user data folder that the browser uses. |
| Open browser timeout (seconds) | Configure the browser startup timeout. |
| Dismiss Alerts | Enable auto-dismissal of JavaScript alert dialogs. |
| Dismiss Confirms | Enable auto-dismissal of JavaScript confirm dialogs. |
| Dismiss Prompts | Enable auto-dismissal of JavaScript prompt dialogs. |
| Confirm dialog response | Set the response to JavaScript confirm dialogs: Cancel or OK . |
| Prompt dialog response | Set the response to JavaScript prompt dialogs: Cancel or OK . |
| Prompt response text | Set the text response for JavaScript prompt dialogs. |
Keyboard Events
The settings below apply to the Type Into and Keyboard Shortcuts activities.
| Type Into - Click before typing | Whether to click the specified UI element before typing the text, and the type of click to perform. The following options are available:
| Type Into - Empty field | Whether to delete the existing content before typing the text, and how to clear the field. The following options are available:
| Type Into - Clipboard | Indicates whether the clipboard is used to type the given text. The following options are available:
| Type Into - Delay between keys (seconds) | Delay time between consecutive keystrokes. |
| Keyboard Shortcuts - Delay between shortcuts (seconds) | Delay time between consecutive special keys. |
| Keyboard Shortcuts - Delay between keys (seconds) | Delay time between consecutive keystrokes. |
SAP
The settings described in the following table apply to any UI Automation activity during SAP automation.
This project setting applies to both Classic and Modern UI Automation activities.
| Enforce hard timeout (only for SAP WinGUI) | Enforces a hard timeout for all activities performing SAP WinGUI automation. |
| Enable additional scaling | Enables SAP WinGUI additional scaling, to support SAP native multi-monitor scaling awareness. |
| Enable SAP monitoring | Enables the monitoring of SAP automations at runtime. Applies to SAP WinGUI, SAP WebGUI, and SAP Fiori. |
| SAP Logon - Number Of Retries | The number of times that the activity is trying to connect to SAP Scripting interface. |
| SAP Logon - Retry Interval | Specifies the amount of time (in seconds) between each entry. |
ScreenPlay
The settings below apply to the ScreenPlay activity. Settings changed here take effect at Runtime if the corresponding property is left blank in the activity.
| Model | Indicates the underlying LLM used by ScreenPlay for task execution planning and reasoning. The following options are available:
| Type by clipboard | Indicates whether the clipboard is used for typing the given text. The following options are available:
| Max number of steps | The maximum number of steps that ScreenPlay can take to achieve its goal. |
| Use DOM when available | Indicates whether DOM data will be used/sent to the LLM Model for applications where DOM can be extracted. DOM can be used only by UiPath LAM implementations. Disable if DOM-based targeting leads to incorrect element coordinates. |
| Logging | Specifies at what level the logs generated by the ScreenPlay activity are stored. The following options are available:
| Enable trace files | Specifies the type of trace files generated by the ScreenPlay activity. The following options are available:
| Trace files retention (days) | Number of days to retain traces before deletion. Set to 0 to keep the traces indefinitely. |
Other Activities
The settings below apply to the Check App State, Extract Table Data, Highlight, Hover, Inject Js Script, Close Popup, and SAP Logon activities.
| Check App State - Timeout (seconds) | How long to wait for the target element to appear or disappear. |
| Extract Table Data - Delay between pages (seconds) | If the data spans multiple pages, how long to wait for each page to be loaded. |
| Highlight - Duration (seconds) | How long to highlight the target element. |
| Hover - Duration (seconds) | How long to hover over the target element. |
| Inject Js Script - Execution world | Applies the InjectJs.ExecutionWorld setting globally. For details, see the Inject Js Script activity. |
| Close Popup - Popup Appear Timeout | The amount of time (in seconds) to wait for a pop-up to appear. |
Robot Logging
Information about the methods used to identify targets and anchors, and the performance of each method at runtime can be saved in the Robot execution logs. The options apply to all supported activities.
| Property name | Property Description | Impacted Activities |
| Log target & anchor search steps | Specifies at what level we store the logs for the methods used to identify targets and anchors. The following options are available:
| Log targeting methods timings | Specifies at what level we store the logs for the performance of each targeting method. The following options are available:
| Log audit information | Specifies at what level the logs generated by the Use Application/Browser activity are stored. The following options are available:
| Use Application/Browser |
