- Overview
- UI Automation
- About the UI Automation activity package
- Applications and technologies automated with UI Automation
- Project compatibility
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Accessibility Check
- Application Event Trigger
- Block User Input
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Element Scope
- Extract Table Data
- Find Elements
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Save Image
- Select Item
- Set Browser Data
- Set Clipboard
- Set CV Server
- Set Runtime Browser
- Set Focus
- Set Project Setting
- Set Text
- Take Screenshot
- Type Into
- Unblock User Input
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Enabling Computer Vision for mobile automation
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Terminal
- Release notes
- About the Terminal activity package
- Best practices
- Find Text
- Get Color at Position
- Get Cursor Position
- Get Field
- Get Field at Position
- Get Screen Area
- Get Text
- Get Text at Position
- Move Cursor
- Move Cursor to Text
- Send Control Key
- Send Keys
- Send Keys Secure
- Set Field
- Set Field at Position
- Terminal Session
- Wait Field Text
- Wait Screen Ready
- Wait Screen Text
- Wait Text at Position
- Terminal coded automation APIs
Enabling Computer Vision for Mobile Automation to identify and interact with UI elements using neural network recognition.
Computer Vision enables you to use UiPath's neural network in order to identify UI elements and interact with them via Robots, simulating human interaction. In the context of Mobile Automation, the Computer Vision feature enhances the number of target elements that you can identify, allowing you to automate UI elements that are otherwise harder to identify and automate.
See the activities that can use Computer Vision in the table below:
| Activity | Description |
| Get Text | Extracts the text from a specified UI element. |
| Set Text | Types the specified text into a target UI element. |
| Tap | Returns a boolean variable that states whether a specified UI element exists. |
| Swipe | Swipes the screen in a specified direction and for a specified amount of times. |
| Element Exists | Returns a boolean variable that states whether a specified UI element exists. |
To start discovering mobile UI elements using Computer Vision, you need to set up your Computer Vision server, for either cloud or on-premises servers. You can set up the Computer Vision server in the Project Settings menu of the project that you are working in.
The Computer Vision configuration section is split into three other sub-sections:
- Server - the URL for the type of Computer Vision server that you want to connect to: cloud or on-premises. The default value for the Run value and Debug value server fields is the cloud instance of Computer Vision:
https://cv.uipath.com. - Api Key - the Computer Vision's API key, specific for your organization.
- Use Local Server - use a local Computer Vision server.
Known limitation
Computer Vision for mobile automation doesn't support CJK (Chinese, Japanese, Korean) languages.
Cloud Computer Vision server
To connect to a cloud Computer Vision server, you can authenticate using an API key, or a User token.
API key
- In the Project panel, go to Project Settings, Mobile Automation, and then focus on the Computer Vision section.
- Under Server in the Run value and Debug value fields, input the URL of a Computer Vision cloud server.
https://cv.uipath.comis the default value. For changing the endpoint, visit Public endpoints. - Input your organization's Computer Vision API key. Visit API keys to learn how to get your Computer Vision API key.
Authenticating to the Computer Vision server
Visit Authentication to learn how to authenticate to the Computer Vision Server, so you can use the corresponding capabilities inside your project.
Related articles
To learn how to configure your cloud Computer Vision server, visit the resources below:
Enabling local Computer Vision server
Follow these steps to use a Computer Vision local server:
- Install the
UiPath.ComputerVision.LocalServerpackage. - In the Project panel, go to Project Settings, Mobile Automation, and then focus on the Computer Vision section.
- Under Use Local Server, set the Run value and Debug value to
True.
