- Overview
- UI Automation
- About the UI Automation activity package
- Applications and technologies automated with UI Automation
- Project compatibility
- UI Automation Classic Project Settings
- UI Automation Modern Project Settings
- UI Automation Project Settings
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Accessibility Check
- Application Event Trigger
- Block User Input
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Element Scope
- Extract Table Data
- Find Elements
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Save Image
- Select Item
- Set Browser Data
- Set Clipboard
- Set CV Server
- Set Runtime Browser
- Set Focus
- Set Project Setting
- Set Text
- Take Screenshot
- Type Into
- Unblock User Input
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Terminal
- Release notes
- About the Terminal activity package
- Best practices
- Find Text
- Get Color at Position
- Get Cursor Position
- Get Field
- Get Field at Position
- Get Screen Area
- Get Text
- Get Text at Position
- Move Cursor
- Move Cursor to Text
- Send Control Key
- Send Keys
- Send Keys Secure
- Set Field
- Set Field at Position
- Terminal Session
- Wait Field Text
- Wait Screen Ready
- Wait Screen Text
- Wait Text at Position
- Terminal coded automation APIs
Project settings for Classic UI Automation activities in Windows Legacy and Windows projects.
These project settings apply for Classic activities in Windows - Legacy, and Windows projects.
Use Project Settings to configure changes at the project level. These global settings impact all activities in the package that have the properties listed below. For more information, see Configuring Activity Project Settings.
The properties configured in Project Settings only take effect in the activities of the workflow if their properties have not been edited. Editing properties manually no longer applies the project settings to them.
To configure the UI Automation Classic project settings, follow these steps:
- In the Project panel, go to Project Settings.
- Navigate to Activities Settings > UI Automation Classic.
- Modify the settings according to what you want to change.
- Click OK to save changes.
You can reset all settings to their default values or copy all values between the debug and production fields using the Bulk Actions drop-down menu at the top of the window.
Generic
The settings below apply to UI Automation Classic activities in Windows - Legacy, and Windows projects that have either one of the following properties.
| Property name | Description |
| DelayBefore | Delay time (in milliseconds) between the previous activity and the current activity. |
| DelayAfter | Delay time (in milliseconds) between the current activity and the next activity. |
| Timeout (milliseconds) | How long to wait for the current activity to be executed before throwing an error. |
| WaitForReady | Before performing the action, wait for the application to become ready to accept input. The following options are available:
| AlterIfDisabled | If set to True , the Select Item action is executed even if the specified UI element is disabled. This property does not apply if the Input Mode property is set to Hardware Events. |
| Capture Screenshots | Dictates if screenshots are captured at design time by all the activities that support this feature. If the setting is set to False , the Remove informative screenshot option from the context menu is disabled. |
| Show closest matches in the 'Element not found' error message | When set to True , this setting shortens the error message that corresponds to an 'Element not found' error. This is useful for protecting sensitive selector information. |
Browser
The settings below apply to the Open Browser and Attach Browser activities.
| Browser |
Choose the type of browser you want to use from the dropdown menu. The following options are available:
| Private | If set to True , the values of variables and arguments are no longer logged at Verbose level. |
| NewSession | If set to True , starts a new session of the selected browser. This option is specific to Internet Explorer. |
| Hidden | If set to True , opens a hidden browser. |
| Enable WebView2 Native Automation | WebView2 is a technology used to integrate browsers in a desktop application or to render web applications as a desktop application. If set to True , The Web2view2 Native Automation project setting can be used to steer the automation of embedded browsers (e.g. embedded Edge) with HTML attribute-based selectors. |
| Enable workaround for simulate click with MV3 extension | Enables a workaround for the issue where the Click activity would fail on certain web page elements when used with the Simulate input method.See more details in Troubleshooting .This setting applies to all clicks performed with Simulate input method - Classic Click, Modern Click etc. |
| CommunicationMethod |
Choose the communication method. The following options are available:
| UserDataFolderMode |
The user data folder mode you want to set. It is used to start the browser with a specific user data folder. There are several
options:
| UserDataFolderPath |
The user data folder that the browser uses. If not set, defaults to:
| Runtime Browser |
The
Runtime Browser
project setting enables you to switch the browser at runtime. It can be used to execute on another browser than the one used
at design time. This converts the browser type and selectors automatically if set. This setting has the following options:
| Extra arguments for OpenBrowser Chrome | Extra command line arguments for opening the Chrome browser. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Extra arguments for OpenBrowser Edge | Extra command line arguments for opening the Edge browser. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Custom executable path for OpenBrowser Chrome | Custom executable path for opening the Chrome browser. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Custom executable path for OpenBrowser Edge | Custom executable path for opening the Edge browser. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Enable retry for OpenBrowser Chrome | Retry opening Chrome if the extension NativeHost failed to launch. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Enable retry for OpenBrowser Edge | Retry opening Edge if the extension NativeHost failed to launch. Applies to the Classic Open Browser and the Modern Use Browser activities. |
| Open browser timeout (seconds) | Configure the browser startup timeout. |
Robot Logging
Information saved in the Robot execution logs.
| Log Target Info | If set to True, the UI Automation Classic activities log Activity Type, Activity Display Name, and Selector.Additionally, for the Open Browser activity, Activity type, Activity display name, and URL are logged. |
Tooltip
The settings below apply to the Tooltip activity.
| Timer | Duration time (in milliseconds) until the pop-up is automatically closed. By default, the pop-up does not close. |
Data Scraping
The settings below apply to the Extract Structured Data activity.
| DelayBetweenPagesMs | The amount of time, in milliseconds, to wait until the next page is loaded. If the loading time of the page is longer, this value should be higher. |
Element Exists
The settings below apply to the Element Exists activity.
| Timeout (milliseconds) | Specifies the amount of time (in milliseconds) to wait for the activity to run when the element does not exist.. |
Highlight
The settings below apply to the Highlight activity.
| HighlightTime | The amount of time (in milliseconds) in which the specified UI element is highlighted. |
Keyboard Events
The settings below apply to the Copy Selected Text, Type Into, and Type Secure Text activities.
The SendWindowMessages and SimulateType input methods are mutually exclusive and selecting them both throws an error at Runtime.
| SendWindowMessages | If set to True, the action is executed by sending a specific message to the target application. This input method can work in the background, is compatible with most desktop apps, but it is not the fastest of the methods. |
| ClickBeforeTyping | If set to True, the specified UI element is clicked before the text is written. |
| EmptyField | If set to True, all previously-existing content in the UI element is erased before writing your text. |
| SimulateType | If set to True, the type action is simulated using the technology of the target application. This input method is the fastest and works in the background. |
SAP
The UI Automation Modern Project Settings for SAP apply to both Classic and Modern UI Automation activities.
Send Hotkey
The settings below apply to the Send Hotkey activity.
Mouse Events
The settings below apply to the Click, Double Click, Hover, and Extract Structured Data activities.
| SimulateClick | If set to True, the click action is simulated using the technology of the target application. This input method is the fastest and works in the background. |
| SimulateHover | If set to True, the hover action is simulated using the technology of the target application. This input method is the fastest and works in the background. |
Screenshot
The settings below apply to the Take Screenshot activity.
| WaitBefore | Delay time (in milliseconds) before taking the screenshot of the specified UI element. The default amount of time is 300 milliseconds. |
Other Activities
The setting below applies to the Inject Js Script activity.
| Inject Js Script - Execution world | Applies the InjectJs.ExecutionWorld setting globally. For details, see the Inject Js Script activity. |
