activities
UI Automation activities
Last updated May 8, 2026
Applications and technologies automated with UI Automation
The tables in this section present the applications and technologies which can be automated using the UiPath.UIAutomation.Activities (UIA) package by indicating the minimum required UI Automation package/ Studio version. It also presents the improvements added in later versions for that application/ technology and the prerequisites for using it.
Web browsers
Application/ Technology Minimum required UIA package/ Studio version Improvements added in later versions Prerequisites
Chrome Studio v2016.2
  • The UiPath Extension for Chrome MV3 is available starting with Studio versions 2022.4.1, 2021.10.8, 2020.10.14, 2019.10.9. Also available in all 2022.10 and 2023.4 versions.
  • UIA v19.7.0 - The Chrome Extension can also be installed on Chrome versions lower than v64.
  • UIA v20.4.1 - The Extension for Chrome can be installed using Policy settings.
  • UIA v21.4.3 - Added support for websites that use Shadow DOM for their UI elements.
  • UIA v21.10.3 - ChromiumAPI input method has been implemented.
  • Starting with Studio v2022.4 the UiPath Extension for Chrome can be used to automate Chrome Apps .
  • UIA v22.4.4 - The new Extension for Chrome is also available on Mac.
Extension for Chrome must be installed.
Edge (Chromium) Studio v2019.10.5 (UIA v19.11.3)
  • The UiPath Extension for Edge MV3 is available starting with Studio versions 2022.4.4, 2021.10.8, 2020.10.14, 2019.10.9.
  • UIA v20.10.5 - Added support for Edge IE Mode.
  • UIA v21.10.3 - The Edge Extension supports Java Applets and ActiveX controls in IE Mode.
  • Starting with Studio v2022.4 the UiPath Extension for Edge can be used to automate Edge Apps .
  • Windows 10 version 1803 or higher
  • Microsoft Edge Chromium version 79 or higher
  • Extension for Edge must be installed.
Firefox Studio v2016.2
Internet Explorer Studio v2016.2 N/A Internet Explorer v8.0 or higher
WebDriver UIA v19.10.1
  • UIA v19.10.1 - The WebDriver protocol can only be used with Google Chrome and Mozilla Firefox.
  • UIA v20.4.1 - Added WebDriver protocol support for Microsoft Edge Chromium browser.
  • UIA v21.10.1 - Cross-origin IFRAME support via WebDriver.
Web embedding frameworks
Application/ TechnologyMinimum required UIA package/ Studio versionImprovements added in later versionsPrerequisites
JxBrowserUIA v19.3.0UIA v19.5.0 - Screen and Data Scraping can be used to create automation projects for applications relying on the JxBrowser library. UIA 24.10.0 - Added support for JxBrowser 7 (Chromium based) through the existing Chromium Native automation infrastructure.The project setting UI Automation Classic > Browser > Enable WebView2 Native Automation must be set to True.
Chromium Embedded FrameworkUIA v19.8.0-ceUIA v21.10.3 - UI elements from CefSharp embedded widgets (e.g. SharpBrowser, SAP NWBC with Fiori Launchpad) are recognized as belonging to the host application instance. UIA v22.10 - Support for CEF used in native applications.The project setting UI Automation Classic > Browser > Enable WebView2 Native Automation must be set to True.
WebView2UIA v22.4.3Support for Edge embedded in native applications.The project setting UI Automation Classic > Browser > Enable WebView2 Native Automation must be set to True.
ElectronUIA v22.10Support for Electron applications.The project setting UI Automation Classic > Browser > Enable WebView2 Native Automation must be set to True.
Virtualization technologies
Citrix UIA v18.4.2 - Native support for Citrix XenApps
  • UIA v19.4.1 - You can create browser automations with native selectors for web applications exposed through Citrix Virtual Apps and Desktops.
  • UIA v22.4.4 - Supports automating in nested CitrixApps.
Microsoft Remote Desktop and Apps UIA v19.4.1
  • UIA v20.10.12, UIA v21.10.5, UIA v22.4.3 – Added support for Azure Windows Virtual Desktop client ( msrdc.exe ).
  • UIA 21.10.3 - Applications provisioned through Microsoft RemoteApp can be automated.
Microsoft App-V UIA v19.6.0 Support for web and native applications exposed through the Microsoft App-V virtualization technology. The UiPath Extensions for the underlying technology must be installed and requires a few extra steps (browsers extensions or Java extension; details in Microsoft App-V Support and Limitations ).
VMware Horizon UIA v20.4.1 N/A
ERP applications
SAP WinGUI UIA v20.4.1 N/A SAP WinGUI for Windows 7.40 or higher
SAP WebGUI UIA v22.12.0-preview N/A SAP WebGUI
SAP Fiori UIA v20.10.5 N/A SAP Fiori versions 1.52 and above, which are in Maintenance by SAP.
Salesforce UIA v21.10.3 Salesforce Lightning, with specific Salesforce AURA components path and attributes, and reliable selectors, is now supported in Chrome and Edge.
Application framework
Silverlight Studio v2018.1 (UIA v18.2) N/A
Java Studio v2018.1 (UIA v18.2)
  • UIA v19.7.0 - Added the possibility to create automation projects for OpenJDK.
  • UIA v19.8.0-ce - Selectors for the NetPhantom framework are now natively generated.
  • UIA 22.2 - The injection mechanism has become more reliable and is able to automate applications like .jnlp applications launched with third party applications, like OWS or IcedTea Web.
  • UIA v22.4.4 - Java versions 16 and 17 are now officially supported.
  • UIA v22.4.4 - Improved support for Java Konsis and the custom Java Framework McBeans.
  • The Java Extension is compatible with any version of JRE's, from Java 3 to Java 17.
  • Extension for Java must be installed.
WinForms UIA v2016.2 Automated with the Active Accessibility framework. N/A
Win32 UIA v2016.2 Automated with the Active Accessibility framework. N/A
WPF UIA v2016.2 Automated with the Active Accessibility framework. N/A
VB6/Epic UIA v22.10.2 UIA v22.10.2 - Better VB6/Epic attributes: ctrlid and automationid attributes. N/A
Qt UIA v22.10.2
  • UIA v22.10.2 - Support for applications based on the Qt Framework through the new type of selector tag: qt .
  • For now, only widgets are supported. No QtQuick/QML support available at the moment.
N/A
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
