activities
UI Automation Activities
Last updated Aug 12, 2025
UI Automation Modern Project Settings
These project settings apply for Modern activities in Windows - Legacy, and Windows projects.
Use Project Settings to configure changes at the project level. These global settings impact all activities in the package that have the properties listed below. For more information, see Configuring Activity Project Settings.
Important: The properties configured in Project Settings only take effect in the activities of the workflow if their properties have not been edited. Editing properties manually no longer applies the project settings to them.
To configure the UI Automation Modern project settings, follow these steps:
  1. In the Project panel, go to Project Settings.
  2. Navigate to Activities Settings > UI Automation Modern.
  3. Modify the settings according to what you want to change.
  4. Click OK to save changes.
You can reset all settings to their default values or copy all values between the debug and production fields using the Bulk Actions drop-down menu at the top of the window.
Generic
The settings below apply to UI Automation Modern activities in Windows - Legacy, and Windows projects that have either one of the following properties.
Property nameDescription
Delay after (seconds)Delay time between the current activity and the next activity.
Delay before (seconds)Delay time between the previous activity and the current activity.
Timeout (seconds)How long to wait for the current activity to be executed before throwing an error.
Wait for page loadBefore performing the action, wait for the application to become ready to accept input. The following options are available:
  • None - Does not wait for the target to be ready.
  • Interactive - Waits until only a part of the application is loaded.
  • Complete - Waits for the entire application to load.
Capture screenshotsDictates if screenshots are captured at design time by all the activities that support this feature. If the setting is set to false, the Remove informative screenshot option from the context menu is disabled.
Show closest matches in the 'Element not found' error messageIf set to True, ten suggestions of the closest selector matches that can be used to replace the faulty selectors are displayed in the logs.
Alter disabled elementIf set to True, the Select Item action is executed even if the specified UI element is disabled. This property does not apply if the Input Mode property is set to Hardware Events.
Wait for primary targeting method until timeoutIf set to True, this setting allows the primary targeting method to consume its full timeout until any fallback targeting method can be used.
Ask user on runtime errorIf set to True, a prompt is displayed allowing you to decide what to do next and continue the automation instead of just stopping the execution.
Automatically add UI elements to Object RepositoryIf set to True, all UI elements are automatically added to Object Repository.
Targeting methods - Desktop applications
The settings below apply to indicated targets and anchors for desktop applications.
Input modeSelect how to execute the action:
  • Hardware Events - Simulates the click by using the hardware driver. This is the slowest method, it cannot work in the background, but it is compatible with all desktop applications.
  • Simulate - Simulates the click using accessibility APIs. Recommended in browser automation, Java apps, or SAP. More reliable than Hardware Events. Works even if the target application is not in focus. Test if your target application UI element supports this.
  • Window Messages - Simulates using Win32 messages. Recommended for desktop apps. Usually more reliable than Hardware Events. Sends all text in one go. Works even if the target application is not in focus. Before using this method, test if your target application UI element supports this.
  • Background - Runs actions in the background. Tries to use Simulate where possible, while complex activities (image, native text) run as usual, in the foreground.
    Note: Using the Background input mode with Universal Windows Platform applications is not supported, which means apps of this type cannot be automated in the background.
Selector - default find typeSelect the default type of find used by the UI element selector. The following options are available:
  • Disabled - Does not use the Selector targeting method to find the UIelement.
  • One match - Uses an exact-match approach. This method ensures precise element identification, but may fail if these attributes change dynamically or if the UI lacks stable identifiers.
  • All matches - intentionally produces multiple matches. It is designed to always be used with anchors to refine selection, making it more resilient to slight UI changes while ensuring contextual accurracy.
  • Auto - Automatically chooses the most appropriate find type of the UI element selector: One match or All matches.
The default value is One match.
Computer Vision
If set to True, uses the Computer Vision method. The default value is True.
ImageIf set to True, uses the Image targeting method.
Note: This method is only used for the Check App State activity if the other methods are disabled.
Generate native WPF selectors (Preview)Enable the generation of native WPF selectors for WPF applications.
Targeting methods - Web browsers
The settings below apply to indicated targets and anchors for web applications.
Input mode for Edge, ChromeSelect how to execute the action:
  • Hardware Events - Simulates the click by using the hardware driver. This is the slowest method, it cannot work in the background, but it is compatible with all desktop apps.
  • ChromiumAPI - Performs actions using debugger APIs. Works for Chromium elements only. Sends all text in one go. Works even if the target application is not in focus. For more details, check out the Chromium API page.
    Note: When the browser is started with Chromium API, a ribbon shows up stating that the browser started in debug mode. This message does not appear if the extension is installed via policy.
Input mode for Firefox, IE, Edge in IE ModeSelect how to execute the action:
The default value is All matches.
Computer VisionIf set to True, uses the Computer Vision method. The default value is True.
Targeting methods - Java
The settings below apply to indicated targets and anchors for Java applications.
Targeting methods - SAP
The settings below apply to indicated targets and anchors for SAP.
Computer VisionIf set to True, uses the Computer Vision method. The default value is False.
Verify execution
Settings for all the activities that have the Verify Execution feature.
Timeout (seconds)The amount of time (in seconds) to wait for the verification element to appear/disappear. If Retry is set to True , the action is performed again, followed by the verification, for the duration specified in the Timeout property.
RetryIf set to True, the action is retried for the duration of the activity timeout, if the expected outcome was not achieved. By default, this check box is selected.
Always auto-verify typed textIf set to True, any action that types text is verified using the Verify Execution feature.
Display verification for Click, Hover, Keyboard Shortcuts activitiesIf set to True, the Click, Hover, and Keyboard Shortcuts activities are always verified using the Verify Execution feature.
Application/Browser
The settings below apply to the Use Application/Browser activity.
OpenDefines whether to open the target application before executing activities in it. The following options are available:
  • Never - Never start/open a new application instance or browser window.
  • If not open - Open a new application instance or browser window, if the selector does not match any existing instance.
  • Always - Always open a new application instance or browser window. When opening a new instance, the file path and arguments are used to launch the application.
CloseDefines whether to close the target application after executing activities in it. The following options are available:
  • Never - Do not close the application instance or browser window after executing the activities in scope, even if it was opened by the Use Application/Browser activity.
  • If opened by App/Browser - Close the application instance or browser window only if it was opened by the Use Application/Browser activity.
  • Always - Always close the application instance or browser window after executing the activities in scope.
Window attach mode
Specifies the default window attach mode used by newly added Use Application/Browser activities. The following options are available:
  • Application instance - Inner activities will search in the indicated application instance, including all parent and child windows (alerts, popups, etc). Other instances of the application are excluded.
  • Single window - Inner activities will search only in the indicated window.
Resize windowDefines whether the application/browser is resized when initialized.
  • None – No resize is applied to the application/browser.
  • Maximize – The application/browser is maximized when initialized.
  • Restore to design-time size – The application/browser is resized and moved to the position and size it had when indicated, if possible.
  • Minimize – The application/browser is minimized when initialized.
Runtime browserSpecifies which browser you want to use at runtime. The following options are available:
  • Firefox
  • Edge
  • Chrome
  • None
WebDriver ModeIndicates how the WebDriver is used when opening a new browser session. The following options are available:
  • Disabled - Disables the use of WebDriver.
  • With GUI - The GUI of the browser is displayed.
  • Headless - The browser is launched silently, with no GUI.
Automatically download WebDriverIf set to True, specifies whether you want to automatically download the required WebDriver executable version.
User data folder modeThe user data folder mode you want to set. It is used to start the browser with a specific user data folder.
  • Automatic - Picture In Picture mode uses a different folder than the default mode, automatically generated if User data folder path is not set.
  • Default folder - Uses the default browser folder, no matter if it runs in the main or PIP session.
  • Custom folder - Uses the folder specified in User data folder path or an auto generated path if User data folder path is not set.
User data folder pathThe path to the user data folder that the browser uses.
Open browser timeout (seconds)Configure the browser startup timeout.
Dismiss Alerts
Enable auto-dismissal of JavaScript alert dialogs.
Dismiss Confirms
Enable auto-dismissal of JavaScript confirm dialogs.
Dismiss Prompts
Enable auto-dismissal of JavaScript prompt dialogs.
Confirm dialog response
Set the response to JavaScript confirm dialogs: Cancel or OK.
Prompt dialog response
Set the response to JavaScript prompt dialogs: Cancel or OK.
Prompt response text
Set the text response for JavaScript prompt dialogs.
Keyboard Events
The settings below apply to the Type Into and Keyboard Shortcuts activities.
Type Into - Click before typingWhether to click the specified UI element before typing the text, and the type of click to perform. The following options are available:
  • None
  • Single
  • Double
Type Into - Empty fieldWhether to delete the existing content before typing the text, and how to clear the field. The following options are available:
  • None
  • Single line [End, Shift + Home, Del]
  • Multi line [Ctrl +A, Del]
Type Into - Clipboard
Indicates whether the clipboard is used to type the given text. The following options are available:
  • Never – Never use the clipboard.
  • Always – Always use the clipboard.
  • Whenever possible – Use the clipboard when possible. This depends on the OS and the text to be typed (e.g. if any special key is used, then the clipboard will not be used).
Type Into - Delay between keys (seconds)Delay time between consecutive keystrokes.
Keyboard Shortcuts - Delay between shortcuts (seconds)Delay time between consecutive special keys.
Keyboard Shortcuts - Delay between keys (seconds)Delay time between consecutive keystrokes.
Other Activities
The settings below apply to the Check App State, Extract Table Data, Highlight, Hover, Inject Js Script, Close Popup, and SAP Logon activities.
Check App State - Timeout (seconds)How long to wait for the target element to appear or disappear.
Extract Table Data - Delay between pages (seconds)If the data spans multiple pages, how long to wait for each page to be loaded.
Highlight - Duration (seconds)How long to highlight the target element.
Hover - Duration (seconds)How long to hover over the target element.
Inject Js Script - Execution worldApplies the InjectJs.ExecutionWorld setting globally. For details, see the Inject Js Script activity.
Close Popup - Popup Appear TimeoutThe amount of time (in seconds) to wait for a pop-up to appear.
SAP Logon - Number Of RetriesThe number of times that the activity is trying to connect to SAP Scripting interface.
SAP Logon - Retry IntervalSpecifies the amount of time (in seconds) between each entry.
Robot Logging
Information about the methods used to identify targets and anchors, and the performance of each method at runtime can be saved in the Robot execution logs. The options apply to all supported activities.
Property nameProperty DescriptionImpacted Activities
Log target & anchor search stepsSpecifies at what level we store the logs for the methods used to identify targets and anchors. The following options are available:
  • Off
  • Info
  • Trace
  • Check/Uncheck
  • Check App State
  • Click
  • Extract Table Data
  • Get Text
  • Highlight
  • Hover
  • Keyboard Shortcuts
  • Select Item
  • Type Into
Log targeting methods timingsSpecifies at what level we store the logs for the performance of each targeting method. The following options are available:
  • Off
  • Info
  • Trace
  • Check/Uncheck
  • Check App State
  • Click
  • Get Text
  • Highlight
  • Hover
  • Select Item
  • Type Into
Log audit informationSpecifies at what level the logs generated by the Use Application/Browser activity are stored. The following options are available:
  • Off
  • Info
  • Trace
