- Overview
- UI Automation
- About the UI Automation activity package
- Applications and technologies automated with UI Automation
- Project compatibility
- UI-ANA-016 - Pull Open Browser URL
- UI-ANA-017 - ContinueOnError True
- UI-ANA-018 - List OCR/Image Activities
- UI-DBP-006 - Container Usage
- UI-DBP-013 - Excel Automation Misuse
- UI-DBP-030 - Forbidden Variables Usage In Selectors
- UI-DBP-031 - Activity verification
- UI-PRR-001 - Simulate Click
- UI-PRR-002 - Simulate Type
- UI-PRR-003 - Open Application Misuse
- UI-PRR-004 - Hardcoded Delays
- UI-REL-001 - Large Idx in Selectors
- UI-SEC-004 - Selector Email Data
- UI-SEC-010 - App/Url Restrictions
- UI-USG-011 - Non Allowed Attributes
- UX-SEC-010 - App/Url Restrictions
- UX-DBP-029 - Insecure Password Use
- UI-PST-001 - Audit Log Level in Project Settings
- UiPath Browser Migration Tool
- Clipping region
- Computer Vision Recorder
- Activities index
- Activate
- Anchor Base
- Attach Browser
- Attach Window
- Block User Input
- Callout
- Check
- Click
- Click Image
- Click Image Trigger
- Click OCR Text
- Click Text
- Click Trigger
- Close Application
- Close Tab
- Close Window
- Context Aware Anchor
- Copy Selected Text
- Element Exists
- Element Scope
- Export UI Tree
- Extract Structured Data
- Find Children
- Find Element
- Find Image
- Find Image Matches
- Find OCR Text Position
- Find Relative Element
- Find Text Position
- Get Active Window
- Get Ancestor
- Get Attribute
- Get Event Info
- Get From Clipboard
- Get Full Text
- Get OCR Text
- Get Password
- Get Position
- Get Source Element
- Get Text
- Get Visible Text
- Go Back
- Go Forward
- Go Home
- Google Cloud Vision OCR
- Hide Window
- Highlight
- Hotkey Trigger
- Hover
- Hover Image
- Hover OCR Text
- Hover Text
- Image Exists
- Indicate On Screen
- Inject .NET Code
- Inject Js Script
- Invoke ActiveX Method
- Key Press Trigger
- Load Image
- Maximize Window
- Microsoft Azure Computer Vision OCR
- Microsoft OCR
- Minimize Window
- Monitor Events
- Mouse Trigger
- Move Window
- Navigate To
- OCR Text Exists
- On Element Appear
- On Element Vanish
- On Image Appear
- On Image Vanish
- Open Application
- Open Browser
- Refresh Browser
- Replay User Event
- Restore Window
- Save Image
- Select Item
- Select Multiple Items
- Send Hotkey
- Set Clipping Region
- Set Focus
- Set Text
- Set To Clipboard
- Set Web Attribute
- Show Window
- Start Process
- System Trigger
- Take Screenshot
- Tesseract OCR
- Text Exists
- Tooltip
- Type Into
- Type Secure Text
- Use Foreground
- Wait Attribute
- Wait Element Vanish
- Wait Image Vanish
- Accessibility Check
- Application Event Trigger
- Block User Input
- Check/Uncheck
- Check App State
- Check Element
- Click
- Click Event Trigger
- Drag and Drop
- Element Scope
- Extract Table Data
- Find Elements
- For Each UI Element
- Get Browser Data
- Get Clipboard
- Get Text
- Get URL
- Go to URL
- Highlight
- Hover
- Inject Js Script
- Keyboard Shortcuts
- Keypress Event Trigger
- Mouse Scroll
- Navigate Browser
- Save Image
- Select Item
- Set Browser Data
- Set Clipboard
- Set CV Server
- Set Runtime Browser
- Set Focus
- Set Project Setting
- Set Text
- Take Screenshot
- Type Into
- Unblock User Input
- Window Operation
- Perform browser search and retrieve results using UI Automation APIs
- Web Browsing
- Find Images
- Click Images
- Trigger and Monitor Events
- Create and Override Files
- HTML Pages: Extract and Manipulate Information
- Window Manipulation
- Automated List Selection
- Find and Manipulate Window Elements
- Manage Text Automation
- Load and Process Images
- Manage Mouse Activated Actions
- Automate Application Runtime
- Automated Run of a Local Application
- Browser Navigation
- Web Automation
- Trigger Scope Example
- Enable UI Automation support in DevExpress
- Mobile Automation
- Release notes
- About the mobile device automation architecture
- Get Log Types
- Get Logs
- Get Page Source
- Get Device Orientation
- Get Session Identifier
- Install App
- Manage Current App
- Manage Other App
- Open DeepLink
- Open URL
- Mobile Device Connection
- Directional Swipe
- Draw Pattern
- Positional Swipe
- Press Hardware Button
- Set Device Orientation
- Take Screenshot
- Take Screenshot Part
- Element Exists
- Execute Command
- Get Attribute
- Get Selected Item
- Get Text
- Set Selected Item
- Set Text
- Swipe
- Tap
- Type Text
- Getting started with Mobile Automation APIs
- Managing pop-up dialogs in mobile automations
- Creating variables from selector attributes
- Creating mobile automation workflows
- Using mobile automation for mobile banking application
- Automation for React Native apps
- Terminal
- Release notes
- About the Terminal activity package
- Best practices
- Find Text
- Get Color at Position
- Get Cursor Position
- Get Field
- Get Field at Position
- Get Screen Area
- Get Text
- Get Text at Position
- Move Cursor
- Move Cursor to Text
- Send Control Key
- Send Keys
- Send Keys Secure
- Set Field
- Set Field at Position
- Terminal Session
- Wait Field Text
- Wait Screen Ready
- Wait Screen Text
- Wait Text at Position
- Terminal coded automation APIs
Tutorial for automating a mobile banking application using the Mobile Automation package.
In this tutorial, we explore how to use the Mobile Automation package to automate tasks within a mobile banking application. The tutorial uses the mobile banking simulator provided by Bank of America, and a Google Pixel Emulator from Sauce Labs. We will specifically focus on automating and testing the following actions:
- Logging into the app.
- Implementing a debit card lock.
- Viewing a claim and capturing a screenshot.
The tutorial provides instructions on how to use both activities and APIs for automating these scenarios.
Prerequisites
To use the desired mobile device and application, we have to create them first in Mobile Device Manager (MDM), as follows:
- Add a device from Sauce Labs into MDM. For more information about adding devices, visit Adding Sauce Labs device.
- Add the Bank of America mobile banking simulator into MDM. For more information about adding applications, visit Adding applications.
Sample project
To follow the steps and try out the tutorial yourself, check the following sample project: Mobile Banking Simulator.
Using activities
In this example we use Object Repository elements as input UI elements to activities. To create UI elements for mobile, establish a connection in Mobile Device Manager (MDM) between the target device and application. Then, directly in the Object Repository panel, create each element and use Indicate Element to indicate the specific UI element on the MDM device.
To easily follow the tutorial, check the following list for the Object Repository structure:
- BankOfAmerica application, MobileScreen menu
- backFromClaimDetails
- backFromClaimStatus
- BackToMenu
- firstClaimSeeDetails
- Lock
- LockCard
- Login
- ManageDebitCredit
- Menu
- Password
- swipeMenu
- UserId
- viewmyclaims
Alternatively, you can create a similar workflow using recorded actions. This process involves creating a connection between your device and the application via MDM, performing a series of actions on this connection, and then importing these steps into a sequence. For more information, visit Create workflow using recorder actions.
Steps
Establish a connection between the device and application:
- Add a Mobile Device Connection activity.
- Use Select Connection Details to connect the previously created mobile device and application.
Login to the mobile application:
- Add a Tap activity to select the User ID field, so you can then enter a username.
- Add a Set Text activity to input the username inside the User ID field.
- Add a Tap activity to select the Password field, so you can then enter the password.
- Add a Set Text activity to input the corresponding password.
- Use a Tap activity to select the Login button.
Figure 1. The first activities as part of logging into the application
Lock a debit or credit card:
- Add a Tap activity to navigate to the mobile banking app menu.
- Add a Swipe activity to swipe down in the menu. The goal is to swipe until you find the Manage Debit/Credit section.
- Add a Tap activity to select the Manage Debit/Credit section.
- Add a Tap activity to select the Lock icon for the first card that is displayed.
- Add a Swipe activity to swipe down in the lock card notice. This action allows you to confirm the action by selecting Lock Card.
- Add a Tap activity to select Lock Card.
Figure 2. Activities used for locking the debit card
Take a screenshot of a claim:
- Add a Tap activity to select the back button, and return to the main menu.
- Add a Swipe activity to swipe down in the main menu, until the View My Claims section appears.
- Use a Tap activity to select the View My Claims section.
- Add a Tap activity to select See details for the first claim.
- Use the TakeScreenshot API to take a screenshot of the first claim details.
Figure 3. Activities used to take a screenshot of a claim
Finally, after taking the screenshot, we go back to the main menu of the app, by using the Tap activity to select the Back UI element twice.
Using coded automation
Prerequisites
To automate a mobile application using APIs, record the application mobile elements within the project's Object Repository. For this example, we created a BankOfAmerica application with a general MobileScreen, containing all the UI elements that we use to automate. To create UI elements for mobile, establish a connection in Mobile Device Manager (MDM) between the target device and application. Then, directly in the Object Repository panel, create each element and use Indicate Element to indicate the specific UI element on the MDM device.
Check the following list for the structure of the Object Repository:
- BackToMenu
- Lock
- LockCard
- Login
- ManageDebitCredit
- Menu
- Password
- swipeMenu
- UserId
- viewmyclaims
Steps
Create a variable of type
Connection, using the Connect API, with the second overload version. For this overload, enter the device name and application name as Strings, to establish the connection.[TestCase] public void Execute() { Connection connection = mobile.Connect( "Android mobile device", "BankOfAmericaSimulator"); Log("Connection established");[TestCase] public void Execute() { Connection connection = mobile.Connect( "Android mobile device", "BankOfAmericaSimulator"); Log("Connection established");[TestCase] public void Execute() { Connection connection = mobile.Connect( "Android mobile device", "BankOfAmericaSimulator"); Log("Connection established");[TestCase] public void Execute() { Connection connection = mobile.Connect( "Android mobile device", "BankOfAmericaSimulator"); Log("Connection established");
Optionally, for debugging purposes, you can add a
Logmessage after the connection. -
Log in to the mobile application:
Call the Tap API to click the User ID field. This action allows you to enter the username.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId); -
Use the SetText API to enter a username in the User ID field.
connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId, "john.doe@uipath.com", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId, "john.doe@uipath.com", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId, "john.doe@uipath.com", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.UserId, "john.doe@uipath.com", MobileOptions.SetText().WithSendNewline(false)); -
Call the Tap API to select the Password field so you can enter the password.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password); -
Use the Set Text API to enter a password in the Password field.
The
WithSendNewLine(false)method ensures that the OK keyboard element is not pressed on the mobile device after sending the text. For more information about the available options of the Set Text API, visit MobileOptions.SetTextOptions Class.connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password, "abcde", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password, "abcde", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password, "abcde", MobileOptions.SetText().WithSendNewline(false));connection.SetText(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Password, "abcde", MobileOptions.SetText().WithSendNewline(false)); -
Employ the Tap API to select Login.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Login);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Login);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Login);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Login);
Navigate to the menu of the mobile banking app, using the Tap API:
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Menu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Menu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Menu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Menu); -
Swipe down in the menu, using the Swipe API. The goal is to swipe until you find the Manage Debit/Credit section.
connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, SwipeDirection.Down, 4);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, SwipeDirection.Down, 4);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, SwipeDirection.Down, 4);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, SwipeDirection.Down, 4); -
Select the Manage Debit/Credit section using the Tap API.
The
WithTimeout()method enables the API to pause for a predetermined number of seconds. This pause lasts until the target UI element appears, or an error is thrown.connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, TapTypeEnum.Single, MobileOptions.Tap().WithTimeout(120));connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, TapTypeEnum.Single, MobileOptions.Tap().WithTimeout(120));connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, TapTypeEnum.Single, MobileOptions.Tap().WithTimeout(120));connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.ManageDebitCredit, TapTypeEnum.Single, MobileOptions.Tap().WithTimeout(120)); -
For the first card that is displayed, select the Lock icon using the Tap API.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Lock); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Lock);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Lock); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.Lock); -
Swipe down in the lock card notice, using the Directional Swipe API, so we can confirm the action by selecting Lock Card.
connection.DirectionalSwipe(SwipeDirection.Down);connection.DirectionalSwipe(SwipeDirection.Down);connection.DirectionalSwipe(SwipeDirection.Down);connection.DirectionalSwipe(SwipeDirection.Down); -
Select Lock Card using the Tap API.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.LockCard);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.LockCard);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.LockCard);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.LockCard);
Take a screenshot of a claim.
Go back to the main menu, using the Tap API and the back icon.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.BackToMenu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.BackToMenu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.BackToMenu);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.BackToMenu); -
Swipe down in the main menu, until the View My Claims section appears.
For this step, we use the Swipe API, this time employing the sixth overload. This overload requires an
IElementDescriptorfor the swipe container, and aSelectorTargetfor the target UI element.We first create a
SelectorTargetfor the View My Claims section, and then employ the Swipe API.-
Open MDM and create the connection between the mobile device and application.
Go to the Object Repository and create a new element for the mobile screen.
Select Indicate element.
From the menu, copy the web control identified by the selectors. For this mobile banking app, you have to ensure that WebView selectors as native selectors is selected as a selection option.
Return to the code editor, and create a variable of type
SelectorTarget. Use theMobileTarget.FromSelectormethod which requires as argument the web control you previously copied.SelectorTarget viewMyClaimsTarget = MobileTarget.FromSelector("<mbl android:className='android.widget.TextView' text='View My Claims' />");SelectorTarget viewMyClaimsTarget = MobileTarget.FromSelector("<mbl android:className='android.widget.TextView' text='View My Claims' />");SelectorTarget viewMyClaimsTarget = MobileTarget.FromSelector("<mbl android:className='android.widget.TextView' text='View My Claims' />");SelectorTarget viewMyClaimsTarget = MobileTarget.FromSelector("<mbl android:className='android.widget.TextView' text='View My Claims' />"); -
Use the Swipe API, with the
SelectorTargetvariable, to finish the swipe down action.connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, viewMyClaimsTarget, SwipeDirection.Down, 20);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, viewMyClaimsTarget, SwipeDirection.Down, 20);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, viewMyClaimsTarget, SwipeDirection.Down, 20);connection.Swipe(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.swipeMenu, viewMyClaimsTarget, SwipeDirection.Down, 20);
Tap the View My Claims section.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.viewmyclaims);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.viewmyclaims);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.viewmyclaims);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.viewmyclaims); -
Tap See details for the first claim.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.firstClaimSeeDetails);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.firstClaimSeeDetails);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.firstClaimSeeDetails);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.firstClaimSeeDetails); -
connection.TakeScreenshot();connection.TakeScreenshot();connection.TakeScreenshot();connection.TakeScreenshot();
Finally, after taking the screenshot, we go back to the main menu of the app, by tapping the Back UI element twice.
connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimDetails); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimStatus);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimDetails); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimStatus);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimDetails); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimStatus);connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimDetails); connection.Tap(ObjectRepository.Descriptors.BankOfAmerica.MobileScreen.backFromClaimStatus);
