- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Forwarding application logs to Splunk
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
To successfully set up Kerberos authentication, you must meet the following prerequisites:
Before you can configure Kerberos authentication, work with your IT administrators to ensure the Automation Suite cluster can access your AD.
The following requirements must be met:
- Automation Suite cluster must be on the same network as the AD domain;
DNS must be set up correctly on the network so that the Automation Suite cluster can resolve the AD domain names.
Note: It is critical that the Automation Suite cluster can resolve the ADdomain names
. You can verify this by runningnslookup <AD domain name>
on the host machine.
Generating Kerberos default keytab and username parameters
Option 1: by Running the script (recommended)
- Log in with your AD administrator account on a Windows domain-joined machine.
- Run the keytab-creator.ps1 script as administrator.
- Input the following values to the script:
Service Fabric FQDN
. For example,uipath-34i5ui35f.westeurope.cloudapp.azure.com
.AD domain FQDN
. For example,TESTDOMAIN.LOCAL
.- An AD user account. You can use an existing account, such as
sAMAccountName
, or you can allow the script to create a new one.
<KERB_DEFAULT_USERNAME>
and <KERB_DEFAULT_KEYTAB>
parameters required by the Kerberos setup.
Option 2: Manually
for that account as follows:
To configure the UiPath® cluster to connect to SQL using Windows integrated authentication/Kerberos, you need to perform a few additional steps:
- the SQL server must join the AD domain;
- the Automation Suite cluster must be on the same network as the SQL Server;
- the Automation Suite cluster can resolve the AD and SQL servers` domain names;
- the AD user must have access to SQL server and DB permissions.
To create a new login in SQL Server Management Studio, take the following steps:
a. In the Object Explorer panel, navigate to Security > Logins.
b. Right-click the Logins folder and select New Login. The Login - New window is displayed.
c. Select the Windows Authentication option. The window is updated accordingly.
d. In the Login name field, type the user domain you want to use as a service account.
e. From the Default Language list, select English.
f. Click OK. Your configurations are saved.
If the service account has already been created and added to the Security > Logins section of the SQL Server, please check whether the Default Language of that SQL account is set to English. If it isn't, please make the necessary adjustments.
db_owner
user mapping role, as in the following screenshot.
db_owner
user mapping role with the UiPath® login, grant the following permissions:
db_datareader
db_datawriter
db_ddladmin
EXECUTE
permission ondbo
schema
EXECUTE
permission has to be granted by using the GRANT EXECUTE
SQL command, as follows:
USE UiPath
GO
GRANT EXECUTE ON SCHEMA::dbo TO [domain\)\)user]
GO
USE UiPath
GO
GO
Integrated Security=True
, you need to create a unique keytab for each UiPath® application, as follows. This will be referred to as <KERB_APP_KEYTAB>
for that application.
Generating Kerberos application keytab and username parameters
- Run the service-keytab-creator.ps1 script.
AD domain FQDN
.- The username and password of an AD user account. For example, the AD user account
sAMAccountName
and its password.
<KERB_APP_USERNAME>
and <KERB_APP_KEYTAB>
parameters required by Kerberos.
Option 2: Manually
Run the following script manually:
# Generate keytab file and output it in the desired path
ktpass /princ <AD username>@<AD domain in cap> /pass <AD user password> /ptype KRB5_NT_PRINCIPAL /crypto AES256-SHA1 /out <path to keytab file> -setpass
# Converts AD user's keytab file to base 64
[Convert]::ToBase64String([System.IO.File]::ReadAllBytes("<path to the generated keytab file>"))
<AD username>
will be the <KERB_APP_USERNAME>
corresponding to the <KERB_APP_KEYTAB>
This section explains how you can configure Automation Suite as a Kerberos client for LDAP or SQL access.
, configure Automation Suite as a Kerberos client in one of the following ways:
- Configuring Kerberos authentication via the interactive installer
- Configuring Kerberos authentication via cluster_config.json
Note: If you want to set up different services to run under their own AD account, and access SQL as that AD account, you can specify
ad_username
with that<KERB_APP_USERNAME>
, anduser_keytab
as<KERB_APP_KEYTAB>
under the configuration section of the service.
- In the
cluster_config.json
file, set thekerberos_auth_config.enabled
parameter totrue
. - If you want to use Kerberos for SQL access, configure the
sql_connection_string_template
,sql_connection_string_template_jdbc
, andsql_connection_string_template_odbc
with the Integrated Security flag. - If you want to set up a different AD user per service, take the following steps:
- After updating the
cluster_config.json
, run the installer script to update the configuration. For details, see Managing products.
Sample of updating Orchestrator and the platform to use Kerberos authentication
"kerberos_auth_config": {
"enabled" : true,
"ticket_lifetime_in_hour" : 8,
"ad_domain": "PLACEHOLDER - INSERT ACTIVE DIRECTORY DOMAIN ",
"default_ad_username": "PLACEHOLDER - INSERT KERB_DEFAULT_USERNAME",
"default_user_keytab": "PLACEHOLDER - INSERT KERB_DEFAULT_KEYTAB"
"sql_connection_string_template": "PLACEHOLDER",
"sql_connection_string_template_jdbc": "PLACEHOLDER",
"sql_connection_string_template_odbc": "PLACEHOLDER",
"orchestrator": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_Orchestrator;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"ad_username": "PLACEHOLDER - INSERT KERB_APP_USERNAME for Orchestrator",
"user_keytab": "PLACEHOLDER - INSERT KERB_APP_KEYTAB for Orchestrator"
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"platform": {
"sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_Platform;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"ad_username": "PLACEHOLDER - INSERT KERB_APP_USERNAME for platform",
"user_keytab": "PLACEHOLDER - INSERT KERB_APP_KEYTAB for platform"
"enabled" : true,
"orchestrator": {
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"platform": {
Service groups and services
cluster_config.json
file, or in the ArgoCD UI.
Service group name for
cluster_config.json |
Service group name for ArgoCD |
Included services |
Orchestrator, Webhooks |
Identity, License Accountant (LA), Audit, Location, License Resource Manager (LRM), Organization Management Service (OMS) |
Automation Hub, Task Mining |
Test Manager |
Automation Ops |
AI Center |
Document Understanding |
Insights |
Data Service |
Automation Suite Robots |
Process Mining |
To update Kerberos authentication via the CLI tool, see Updating Kerberos authentication.
For Kerberos authentication to be used when logging in to Automation Suite, you must further configure Automation Suite host settings.
To remove Kerberos authentication completely, take the following steps:
- If you used Kerberos to configure AD integration, reconfigure AD with the username and password option by following the instructions in Configuring the Active Directory integration.
- If you used SQL integrated authentication, configure the SQL connection strings to use User Id and Password.
- Disable Kerberos authentication as follows:
- Go to the ArgoCD UI, find the uipath application, click the APP DETAILS button in the top-left corner, and then navigate to the PARAMETERS tab.
- Click EDIT, and set
global.kerberosAuthConfig.enabled
tofalse
To remove SQL integrated authentication, take the following steps:
- Configure the SQL connection strings to use User Id and Password.
- If want to disable SQL integrated authentication for all the services, set
tofalse
in ArgoCD after changing all of the connection strings
If you encounter any issues while configuring Kerberos, see Authentication troubleshooting.
- Prerequisites
- Ensuring the Automation Suite cluster can access your AD
- Configuring the AD service account for Kerberos authentication
- Optional: SQL authentication prerequisites
- Configuring Automation Suite as a Kerberos client
- Updating Kerberos authentication via CLI tool
- Configuring the Active Directory integration
- Disabling Kerberos authentication
- Removing Kerberos authentication completely
- Removing SQL integrated authentication
- Kerberos troubleshooting
