- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Forwarding application logs to Splunk
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
cluster_config.json
file for all the nodes in the cluster.
fqdn
- update this field with new FQDN that you need to access the cluster.fixed_rke_address
- if this value is identical to thefqdn
field incluster_config.json
, then you need to update this value as well to reflect the new FQDN.Note:Changing the FQDN also requires new server certificates. If a new certificate is available, you have two options: either continue with the new self-signed certificate configured by the installer automatically, or stop the installation and bring in a new certificate.
You can configure the certificate via theserver_certificate
To update the FQDN in single-node evaluation mode, take the following steps:
- Navigate to the
UiPathAutomationSuite
folder (the location of the installer bundle). - Run the following command to update the FQDN:
Online
sudo ./install-uipath.sh -i ./cluster_config.json -o output.json -a --accept-license-agreement
Offline
Run the following command to update the FQDN for the infrastructure:
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k --offline-bundle ./as-infra.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
Run the following command to update the FQDN for the fabric and services:
sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -f -s --accept-license-agreement
To update the FQDN in multi-node HA-ready production mode, take the following steps:
There are some variations between the commands you run on the first server node, those you execute on the subsequent server nodes, and those you use on agent nodes, as follows:
- The
-a
option is exclusively for commands executed on the first server node. This is where you must run the fabric and service installer. - The
-k
option specifically applies to commands run on the following server nodes, and it skips the execution of the fabric and service installer. - The
-j server
option is used to distinguish between server nodes and agent nodes.
