- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Configuring the FQDN post-installation
- Setting up Kerberos authentication
- Setting up Elasticsearch and Kibana
- Forwarding application logs to Splunk
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
The EFK (Elasticsearch, Fluentd, Kibana) stack is a centralized logging solution that allows you to search, analyze and visualize log data. Fluentd collects and sends the logs to Elasticsearch, Kibana retrieves the logs and lets you visualize and analyze the data.
Automation Suite supports Elasticsearch version 7.x. Version 8.x is also supported, but only for advanced configurations.
If your Elasticsearch instance requires credentials, create a secret with its password in the cluster.
kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>
Run the following command to ClusterOutput to Elasticsearch. Replace the following attributes with the ones of your Elasticsearch configuration:
<elasticsearch host>
- the network host of your Elasticsearch instance;<elasticsearch port>
- the Elasticsearch port for client communication;<secret key>
- the secret with the Elasticsearch password;timekey
value inelasticsearch.buffer
- the output frequency i.e. how often you want to push logs;-
elasticsearch.scheme
- the URL scheme. Valid values are:http
orhttps
.kubectl -n cattle-logging-system apply -f - <<"EOF" apiVersion: logging.banzaicloud.io/v1beta1 kind: ClusterOutput metadata: name: es-output spec: elasticsearch: host: <elasticsearch host> port: <elasticsearch port> scheme: <http or https> ssl_verify: false ssl_version: TLSv1_2 user: elastic password: valueFrom: secretKeyRef: name: elastic-user key: <secret key> buffer: timekey: 10m timekey_wait: 30s timekey_use_utc: true EOF
Run the following command to ClusterFlow in FluendD:
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
format: ${namespace_name}/${pod_name}.${container_name}
globalOutputRefs:
- es-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- aicenter-hit-count-update
- exclude:
namespaces:
- fleet-system
- cattle-gatekeeper-system
- default
- exclude:
labels:
app: csi-snapshotter
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
kind: ClusterFlow
metadata:
spec:
filters:
- tag_normaliser:
globalOutputRefs:
- es-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- exclude:
namespaces:
- fleet-system
- default
- exclude:
labels:
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
ClusterOutput
