- Overview
- Requirements
- Recommended: Deployment templates
- Q&A: Deployment templates
- Release notes
- GCP deployment architecture
- Step 1: Preparing the GCP deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment steps
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
Name |
Description |
Parameter type |
Example |
Project in which the resources will be deployed. |
string |
Region where the resources will be deployed. |
string |
Default zone where zonal resources are deployed. The zone should belong to the region you chose. |
string |
Automation Suite installer version. |
string |
Automation Suite installer URL. It overwrites the
installer_version parameter and installs the version from the package.
string |
Automatically install Automation Suite on the provided infrastructure. |
bool |
Fully qualified domain name (FQDN) for Automation Suite. |
string |
Username used to log in VMs via SSH. |
string |
Path to the SSH public key used to access VMs. |
string |
Path to the SSH private key used to access VMs. |
string |
Instance type of server machines. |
string |
Instance type of agents machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes. |
string |
Number of server VMs, must be odd |
number |
Number of agent VMs. |
number |
Number of GPU agent VMs |
number |
(Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image. |
string |
Install Orchestrator. |
bool |
Install AI Center. |
bool |
Install Document Understanding. |
bool |
Install Insights. |
bool |
Install Data Service |
bool |
Install Test Manager. |
bool |
Install Automation Ops. |
bool |
Install Automation Hub. |
bool |
Install Apps. |
bool |
Install Action Center. |
bool |
Install Task Mining. |
bool |
Install Automation Suite Robots. |
bool |
Instance type of ASobots dedicated agents. |
number |
Number of dedicate ASRobots VMs. |
string |
Install Process Mining. |
bool |
By setting the parameter as true, you agree to the applicable license agreement. |
bool |
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
