- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Enabling SSO for ArgoCD
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
uipathctl.sh
script is required to enable SSO authentication. For more details on the script and the parameters you need to use, see .
You must generate the RBAC file and the Dex configuration file before enabling SSO for ArgoCD.
The RBAC file contains access rules. For details on the built-in role definitions, see ArgoCD documentation. For details on the ArgoCD account types and their permissions, see Managing the cluster in ArgoCD. We recommend using these roles when defining your groups, but you can create your own set of permissions.
Configuring the RBAC file
Example:
Say your LDAP group for ArgoCD administrators is "Administrators", and the LDAP group for ArgoCD read-only users is "Readers", the RBAC file should be:
p, role:uipath-sync, applications, get, */*, allow
p, role:uipath-sync, applications, sync, */*, allow
g, argocdro, role:uipath-sync
g, Readers, role:uipath-sync
g, Administrators, role:admin
For more advanced use cases, see the default RBAC file.
# Built-in policy which defines two roles: role:readonly and role:admin,
# and additionally assigns the admin user to the role:admin role.
# There are two policy formats:
# 1. Applications, logs, and exec (which belong to a project):
# p, <user/group>, <resource>, <action>, <project>/<object>
# 2. All other resources:
# p, <user/group>, <resource>, <action>, <object>
p, role:readonly, applications, get, */*, allow
p, role:readonly, certificates, get, *, allow
p, role:readonly, clusters, get, *, allow
p, role:readonly, repositories, get, *, allow
p, role:readonly, projects, get, *, allow
p, role:readonly, accounts, get, *, allow
p, role:readonly, gpgkeys, get, *, allow
p, role:readonly, logs, get, */*, allow
p, role:admin, applications, create, */*, allow
p, role:admin, applications, update, */*, allow
p, role:admin, applications, delete, */*, allow
p, role:admin, applications, sync, */*, allow
p, role:admin, applications, override, */*, allow
p, role:admin, applications, action/*, */*, allow
p, role:admin, applicationsets, get, */*, allow
p, role:admin, applicationsets, create, */*, allow
p, role:admin, applicationsets, update, */*, allow
p, role:admin, applicationsets, delete, */*, allow
p, role:admin, certificates, create, *, allow
p, role:admin, certificates, update, *, allow
p, role:admin, certificates, delete, *, allow
p, role:admin, clusters, create, *, allow
p, role:admin, clusters, update, *, allow
p, role:admin, clusters, delete, *, allow
p, role:admin, repositories, create, *, allow
p, role:admin, repositories, update, *, allow
p, role:admin, repositories, delete, *, allow
p, role:admin, projects, create, *, allow
p, role:admin, projects, update, *, allow
p, role:admin, projects, delete, *, allow
p, role:admin, accounts, update, *, allow
p, role:admin, gpgkeys, create, *, allow
p, role:admin, gpgkeys, delete, *, allow
p, role:admin, exec, create, */*, allow
g, role:admin, role:readonly
g, admin, role:admin
The Dex configuration file contains the parameters required to configure SSO for ArgoCD.
ldap_connector.yaml
), skip to Enabling the SSO for ArgoCD.
To configure SSO through LDAP, take the following steps:
After preparing the RBAC and the Dex configuration file, you can enable SSO for ArgoCD:
Update the cluster_config.json file with the following parameters:
fabric.argocd_dex_config_file
- enter the path to the previously created Dex configuration file. -
fabric.argocd_rbac_config_file
- enter the path to the previously created RBAC file.
Rerun the fabric installer:
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement
