- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. Refer to the following table for the names you need to use.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
The following table lists out the database names and their corresponding format.
Product / service |
Default database name |
Connection string format |
Shared Platform Capabilities |
Orchestrator |
Action Center |
Automation Suite Robots |
Automation Hub |
Data Service |
Insights |
Test Manager |
Task Mining |
AI Center |
Apps | AutomationSuite_Apps 1 | ODBC |
Document Understanding |
Process Mining |
AutomationSuite_ProcessMining_Warehouse 2AutomationSuite_Airflow 3 |
uses both ADO.NET and PYODBC formats.
uses PYODBC connection string format. AutomationSuite_Airflow
must have READ_COMMITTED_SNAPSHOT
enabled when creating databases manually. The connection to the AutomationSuite_Airflow
database can not begin with a {
character.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
- for SQL: add
at the beginning and end of the password, and double any other'
. - for JDBC/ODBC: add
at the beginning of the password and}
at the end, and double any other}
You could use the databases in an elastic pool for better cost-effectiveness.
dbcreator
role to the SQL account used to connect to the database.
db_owner
and db_securityadmin
roles for all Automation Suite databases. We only use the db_securityadmin
role during installation or if the databases are reprovisioned, so you may revoke that permission afterwards.
db_owner
, then the SQL account should have the following roles and permissions on all databases (the only exception is Insights which
still requires db_owner
db_securityadmin
db_ddladmin
db_datawriter
db_datareader
EXECUTE
permission on dbo schema
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also check here all the components that can be added to the SQL Server, which includes also Full-Text Search.
.json
functions.
For Azure SQL, ensure the database is S3 service objective or above.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
Data Service requires SQL Server version 2016 or higher.
Latin1_General_CI_AS
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};
for data storage for Process Mining process apps.
databases. Non-standard SQL server ports are not supported.
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database and a dedicated Process Mining database are installed, is set to UTC.
To calculate the hardware requirements, you need to have an indication of:
- the number of (million) events in your process.
the number of case and event fields in your output data.
Note: In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the Capacity calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
See also Hardware requirements.
db_securityadmin
is required on the Process Mining data warehouse SQL Server to enable per app security. See the official Microsoft documentation
on Database-level roles.
See also Configuring process app security.
AutomationSuite_Platform
for
AI Events and AI Storage services.
Before starting the Automation Suite installation, take the following steps:
Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
nmap -sV -p <port> -vv --script ssl-cert domain
During the Automation Suite installation, take the following steps:
Append the following values to the AI Center
sql_connection_string_template_jdbc
connection string in thecluster_config.json
file:encrypt=true;trustServerCertificate=false;fips=true;
.Example:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"For details on database configuration, see Advanced installation experience and Updating the SQL database.
Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
For comprehensive details, see the SQL Server configuration section in the Orchestrator guide.
option is set to ON
is enabled or
disabled:
SELECT is_read_committed_snapshot_on FROM sys.databases
WHERE name= 'UiPath'
1
0
. Use this query to
enable it:
ALTER DATABASE UiPath
SET READ_COMMITTED_SNAPSHOT ON
must be enabled on those as well.
- Databases
- Permissions
- SQL requirements for Full-Text Search
- SQL requirements for Insights
- SQL requirements for Data Service
- SQL requirements for Process Mining
- SQL requirements for AI Center
- Requirements for AI Center connected to an external Orchestrator
- Requirements for AI Center installed on a FIPS 140-2-enabled machine
- SQL requirements for HA
- SQL requirements for Orchestrator
