Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
Due to a Longhorn bug, the race condition causes the replica size to expand. To check if the volume faces this issue, look for the following error in the Longhorn manager logs:
-- 9776:2023-10-12T00:17:01.290911721Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Creating volume pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25 controller with iSCSI target request timeout 15s and engine to replica(s) timeout 8s" 9777:2023-10-12T00:17:01.298832774Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=info msg="Starting with replicas [\"tcp://10.42.2.132:10015\"]" 9780:2023-10-12T00:17:01.322556233Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=warning msg="Backend tcp://10.42.2.132:10015 size does not match 3221225472 != 16106127360 in the engine initiation phase" 9782:2023-10-12T00:17:01.330974089Z [pvc-1f5d7c52-819a-4d4a-ac36-4f42541bdd25-e-41a36772] time="2023-10-12T00:17:01Z" level=error msg="no available backend due to replica error from the addresses [tcp://10.42.2.132:10015]" ---
Alternatively, check if the volume shows in expansion state in the Longhorn UI.
To fix this issue, take the following steps:
Scale down the application/workload pod.
Expand the PVC to the size of the replica.
Scale up the application/workload pod.
For details, see the official Longhorn documentation.
