Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
If you experience issues specific to Kubernetes running on the cluster, you can directly uninstall the rke2 cluster.
Depending on your installation profile, run one of the following commands:
1.1. In an online setup, run the following script with elevated privileges, i.e.sudo
, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."
function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."1.2 In an offline setup, run the following script with elevated privileges, i.e.sudo
, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."
function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete." -
Clean up the OSD disk:
for osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do devName=$(basename "${osddisk}") devPath="/dev/${devName}" sgdisk --zap-all "${devPath}" dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync blkdiscard "${devPath}" done ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove % rm -rf /dev/ceph-* rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rules
for osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do devName=$(basename "${osddisk}") devPath="/dev/${devName}" sgdisk --zap-all "${devPath}" dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync blkdiscard "${devPath}" done ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove % rm -rf /dev/ceph-* rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rules3, Reboot the node after uninstall.
Important: When uninstalling one of the nodes from the cluster, you must run the following command:kubectl delete node <node_name>
. This removes the node from the cluster.
