Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Step 1: Removing old Identity cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Clearing Redis data
- Step 4: Validating the Insights migration
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
O remove the old Identity cache keys, take the following steps:
- Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.password }}'
to get Redis password. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> get secrets/redb-redis-cluster-db -n uipath --template '{{ .data.port }}'
to get Redis port. Decode the Base64 value. - Run
kubectl --kubeconfig <directory of SF cluster yaml file> exec -i -t -n redis-system redis-cluster-0 -c redis-enterprise-node "--" sh -c "clear; (bash || ash || sh)"
to get into Redis node. - Use port and password got from previous commands to run
redis-cli -p <Port number> -a <Password> --scan --pattern is:* | xargs redis-cli -p <Port number> -a <Password> del
to delete the old keys. - Run exit to get out.
