- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Accessing Automation Suite
- Managing the certificates
- Updating the SQL connection strings
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
The installation process generates self-signed certificates on your behalf. These certificates are FIPS-compliant and will expire in 90 days. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working in 90 days.
If you installed Automation Suite on a FIPS-enabled host and want to update the certificates, make sure they are FIPS-compliant.
The installation bundle provides a cluster management tool that enables you to update certificates post-installation. To access the tool, navigate to the location of the installer bundle:
cd /opt/UiPathAutomationSuite/
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr
[SAN]
EOF
Your IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
To view more information about server certificates, run the following command:
sudo ./configureUiPathAS.sh tls-cert --help
Output:
Manage cluster tls and server certificate
Usage:
configureUiPathAS.sh tls-cert [command]
configureUiPathAS.sh tls-cert [flags]
Available Commands:
update Update the tls / server certificate
get Get the tls / server certificate
Flags:
-h|--help Display help
Usage:
Available Commands:
Flags:
command.
Online installation: How to find the server certificate
istio-ingressgateway-certs
name in the istio-system
namespace.
See the certificate files in the following list:
- Server TLS certificate is stored as
tls.crt
- Server TLS private key as
tls.key
- CA bundle is stored as
ca.crt
You can verify the secrets using the following command :
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yaml
Certificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, see Understanding the container architecture related to certificates.
Offline installation: How to find the server certificate
rootCA.crt
and tls.crt
: ArgoCD and Docker Registry. Certificates are then stored in both Docker and ArgoCD namespaces.
# For docker registry
kubectl -n docker-registry get secrets docker-registry-tls -o yaml
# For Argocd
argocd cert list --cert-type https
# For Argocd
How to update server certificates
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key
script to update the certificate as shown below. You need the path to each of the three certificate files. All the certificate
file should be in PEM
format.
- Certificate Authority Bundle - This bundle should contain only the chain certificates used to sign the TLS server certificate. The chain limit is up to nine certificates.
- Server Certificate - Public server certificate
Private key - Private key for server certificate
sudo ./configureUiPathAS.sh tls-cert update --ca-cert-file /path/to/cacert --tls-cert-file /path/to/tlscert --tls-key-file /path/to/tlskey
/directory/path/to/store/certificate
location.
To print out the certificate files, run the following command, specifying the directory where certificates are stored.
sudo ./configureUiPathAS.sh tls-cert get --outpath /directory/path/to/store/certificate
You are responsible for making sure the generated certificates are trusted.
To add the certificate to the host VM trust store, run the following commands on all the nodes in the cluster:
# 1. Copy the certificate file to the /usr/share/pki/ca-trust-source/anchors/ or the /etc/pki/ca-trust/source/anchors/ directory
cp /path/to/the/ca-cert /usr/share/pki/ca-trust-source/anchors/
# 2. Update the trust store configuration
update-ca-trust
update-ca-trust
To view more information about additional CA certificates, run the following command:
./configureUiPathAS.sh additional-ca-certs --help
Output:
Manage additional CA certificates, this can be used to add sql server CA
Usage:
configureUiPathAS.sh additional-ca-certs [command]
configureUiPathAS.sh additional-ca-certs [flags]
Available Commands:
update Update the additional trusted CA certificates.
get Get the additional trusted CA certificates
Flags:
Usage:
Available Commands:
Flags:
additional-ca-certs
command.
This command helps you update or replace the existing configured CA certificates.
./configureUiPathAS.sh additional-ca-certs update --ca-cert-file /path/to/ca/certs
--replace
at the end.
.pem
format and can have more than one certificate present in it.
To download the already configured CA certificates, run the following command:
./configureUiPathAS.sh additional-ca-certs get --outpath /path/to/download/certs
update-ca-trust
update-ca-trust
To view more information about identity token-signing certificates, run the following command:
sudo ./configureUiPathAS.sh identity token-cert --help
Output:
Manage Identity token signing certificate
Usage:
configureUiPathAS.sh identity token-cert [command]
configureUiPathAS.sh identity token-cert [flags]
Available Commands:
update Update secondary certificate to signing
the authentication token
rotate Switch secondary certificate as a primary
get Get token signing certificate
Flags:
Usage:
Available Commands:
Flags:
token-cert
command.
To upload the new certificate to sign the token, run the following command:
The following command does not replace the existing token signing certificate.
.pem
format.
sudo ./configureUiPathAS.sh identity token-cert update --cert-file-path /path/to/cert --cert-key-file-path /path/to/certkey
To rotate or replace the old certificate with the new one, run the following command:
sudo ./configureUiPathAS.sh identity token-cert rotate
There should be the lead time of about 24 - 48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
If you rotate the certificate too soon before the expiry of cache token can result in downtime. And you may have to restart all your robots.
To perform an emergency certificate update, take the following steps:
By default, RKE2 certificates expire in 12 months. In the 90 days prior to their expiration date, certificates are rotated when you restart RKE2.
For more details, refer to RKE2 - Advanced Options - Certificate rotation.
# Directory path to check
if [[ -d "/var/lib/rancher/rke2/server/tls" ]];
then
dir="/var/lib/rancher/rke2/server/tls"
else
dir="/var/lib/rancher/rke2/agent/tls"
fi
# Loop through each .crt file in the directory
for file in "$dir"/*.crt;
# Extract the expiry date from the certificate
do
expiry=$(openssl x509 -enddate -noout -in "$file" | cut -d= -f 2-)
# Get the file name without the path
filename=$(basename "$file")
# Print the filename and expiry date in a pretty format
printf "%-30s %s\n" "$filename:" "$expiry"
done
then
else
fi
do
done
The output you get should be similar to the one shown in the following image:
To rotate the RKE2 certificates, you must first execute a series of action on the server nodes, then proceed with some steps on the agent nodes.
- Stop the RKE2 server:
systemctl stop rke2-server.service
systemctl stop rke2-server.service - Clear any remaining RKE2 processes:
rke2-killall.sh
rke2-killall.sh - Delete the
dynamic-cert.json
file located at/var/lib/rancher/rke2/server/tls/
. - Restart the RKE2 server:
systemctl start rke2-server.service
systemctl start rke2-server.serviceNote: If the cluster has more than one server node, steps 1-4 might not wholly execute as etcd may be unable to complete the leader election. Should this happen, repeat steps from 1-4 on other server nodes. - Delete the
rke2-serving
secret from thekube-system
namespace:kubectl delete secret -n kube-system rke2-serving
kubectl delete secret -n kube-system rke2-servingNote:In a multi-node deployment, you may not be able to run thekubectl
commands until you have completed the first four operations on the necessary number of server nodes. This is to fulfill the etcd quorum requirement. You can remove therke2-serving
secret immediately after the RKE2 server starts up.
kubectl get nodes
command. When your server nodes are ready, you can proceed to the agent nodes to regenerate the certificates.
Take the following steps on the agent nodes:
systemctl stop rke2-agent.service
systemctl stop rke2-agent.service - Clear any remaining RKE2 processes:
rke2-killall.sh
rke2-killall.sh - Restart the RKE2 server:
systemctl start rke2-agent.service
- Generating a Certificate Signing Request (CSR) and a private key
- Managing server certificates
- Updating the server certificate
- Accessing the TLS certificate
- Adding the CA certificate to the host trust store
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Updating the certificate
- Rotating the certificate
- Emergency certificate rotation
- Accessing the certificate
- Managing Rancher certificates
- Checking the RKE2 certificate expiration date
- Rotating the RKE2 certificate
- Managing the external OCI-compliant registry certificate
