Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Completing an upgrade
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
After performing an Automation Suite cluster upgrade, some changes are needed to ensure a new node joins the cluster correctly
through scale-out operations. To automate the changes, we recommend using the
upgrade_wrapper.py
script.
Make sure you meet the following requirements:
- Python 3.8 or newer must be installed on the machine on which you execute the script. For details, see Python documentation.
- Python packages are required for the script. You can install these packages using the following pip command. For details,
see pip documentation.
pip install wget requests boto3
pip install wget requests boto3 boto3
clients must be able to authenticate to AWS because deployment changes occur through them. You can provide credentials as environment variables or through a default profile using a shared credential file. The user must have the permission to perform the actions described in the Script behavior section.-
Ensure your RHEL version for the Auto Scaling Group (Server, Agent, etc.) is updated and matches the version you are upgrading to.
- Make sure to review the
cluster_config.json
file and change any boolean values marked as string ("true"
/"false"
) to actual boolean values (true
/false
). For example:- to enable zone resilience, use
"zone_resilience": true
. - to allow the installer to create the databases, use
"sql.create_db": true
- If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or newer, and Orchestrator is enabled on both the
old and new versions, you must set the
orchestrator.block_classic_executions
flag totrue
in thecluster_config.json
file. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - If you upgrade to Automation Suite 2023.10 or later, and Insights is enabled on both the old and new environments, you must
set the
insights.external_object_storage.bucket_name
flag to the same bucket used forplatform
file. Not using the flag causes the upgrade operation to fail. This parameter is not required in new installations. - If you upgrade to Automation Suite 2023.10 or newer, make sure to fill in the following fields in the
cluster_config.json
ifsql.create_db
is set totrue
:sql.server_url = "<db_endpoint>" sql.port = "1433" sql.username = <SQL Username> sql.password = <SQL password>
When running the
upgrade_wrapper.py
script, take into consideration the fact that it performs the following operations:
- Downloads in the current folder the dependencies needed;
- Extracts information from the Automation Suite deployment stack;
Creates a new stack containing:
- A new Launch Template for each Auto Scaling Group present in the initial deployment with the changes needed for the new version installation flow;
An IAM policy attached to the IAM role used by the Automation Suite nodes that allows the
DescribeStackResource
operation on the current stack;Note: The policy is deployed only if a custom IAM role was not provided at deployment time. Otherwise you should grant thecloudformation:DescribeStackResource
permission on the newly deployed stack to the IAM role used by the Automation Suite nodes.
- Updates the Auto Scaling Group to use the Launch Templates created in the new stack;
- Updates the SSM parameter containing the installer URL (optional, depending on the initial deployment template version);
Overrides the old installer used in the initial deployment with the one used for upgrade on all nodes through an SSM Run Command. This is needed to preserve the functionality of the SSM documents already existent in the initial deployment;
Note: The AMI update SSM document might no longer work after the Launch template update. The IAM role used by the SSM documents should be updated with theec2:CreateLaunchTemplateVersion
permission, andec2:RunInstances
permissions on the newly created Launch Templates. - Cleans up the downloaded files.
