Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Copy the Orchestrator Certificate
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
If AI CenterTM requires an external Orchestrator, you need to copy the Orchestrator and Identity Server certificate to the virtual machine before the installation or upgrade.
Note: In case of chain certificates, make sure to use the root certificate as show in Chain certificates section below.
Download and save the Orchestrator certificate on your local machine. You can do this by using a browser, or you can ask your
IT department to provide the certificate. Certificates must be base64 and
.cer
format. Copy the certificate to the virtual machine using the command below.
scp /path/to/orch.cer <username>@<node dns>:/opt/UiPathAutomationSuite
If Identity Server is different from Orchestrator, repeat the steps for
identityserver.cer
as well.
Chain certificates
When using a domain-issued certificate, make sure to export the root certificate as follows:
The resulting file should be similar to the example below.
-----BEGIN CERTIFICATE-----
certificate
base64
encoded
-----END CERTIFICATE-----
certificate
base64
encoded
