Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Manual: Installing Automation Suite
- Disaster recovery - Installing the secondary cluster
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
To install the secondary Automation Suite cluster in an Active/Passive or Active/Active deployment, take the following steps.
Generate or copy the
cluster_config.json
file from the primary Automation Suite cluster to one of the nodes identified as the server in the secondary Automation Suite cluster. For more details, see Generating or copying the cluster_config.json of the primary cluster. -
Update the
cluster_config.json
file with the parameters specific to the secondary Automation Suite cluster. -
Resume the Automation Suite installation.
Switch off inactive products if you use an Active/Passive configuration.
Generate a new
cluster_config.json
file or copy it from the primary cluster.
Update the
cluster_config.json
file with the parameters specific to the secondary Automation Suite cluster by taking the following steps:
Once the parameters in the previous step are provided or modified in the
cluster_config.json
, you can resume the installation as instructed in Installing Automation Suite.
Note:
You must perform the Automation Suite installation using the
install-uipath.sh
installer. Note that you do not need to generate a new cluster_config.json
If you deployed Automation Suite in Active/Passive mode, you can scale down the cluster and switch off inactive products using the following command. This step is not required if you opt for an Active/Active setup.
./configureUiPathAS.sh products scale-down
