- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Installation best practices
- Encrypting the SQL Server
- Performing database maintenance
- Performing yearly certificate maintenance
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
We recommend rotating certificates before their expiration date. Make sure to schedule a downtime period to address potential issues. To be informed in a timely manner of the certificate expiration dates, configure alerts for your cluster. Doing so prevents service disruptions. For more details, see Alert runbooks.
We highly recommend performing the following yearly maintenance tasks:
Renew the SSL certificate. For details, see Managing server certificates.
Renew the identity certificate. For details, see Managing identity token-signing certificates .
Renew the internal Kubernetes certificate. For details, see Managing Rancher certificates.
Renew the cattle webhooks certificate. For details, see the Rancher documentation.
Clean up logs manually. For details, see How to clean up logs.
