- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
After a Disaster Recovery, Dapr is not restored properly, and the certificates needed by dapr to provide services for Process Mining and Task Mining are incorrect. The dapr, processmining, and taskmining applications appear to be healthy first, but will then go back to progressing state and the environment becomes unstable. When logging in to Process Mining or Task Mining, the application may not load, or return unexpected errors.
This page describes the steps you should take to resolve the issue.
Follow these steps to check whether dapr is working properly.
Open ArgoCD and go to Applications.
Select the
processmining
application card to open theprocessmining
app details tree. -
Locate the
processmining
pods and check the number of containers in the pod. For a proper working ofprocessmining
there must be 3 containers in the pod. In the above example, there are 2 containers in the pod, which means that there is one container missing. -
Open the pod and select the LOGS tab. Select
processmining
to see the available logs. -
Check whether the
daprd
log file is present. If there is no log file for dapr, this indicates that dapr is not configured properly.
Delete all dapr secrets and the mutatingwebhookconfiguration.
Resync all dapr secrets and the mutatingwebhookconfiguration.
Restart dapr-sentry deployment and wait to the deployment is finished.
Restart dapr-operator deployment and wait to the deployment is finished.
Restart dapr-sidecar-injector deployment and wait to the deployment is finished.
Below is a detailed description of the steps.
Go to Applications in ArgoCD.
Select the dapr application card to open the dapr app details tree.
Locate the dapr secrets. The secrets must be recreated. You can do this by deleting each secret.
Open the context menu of the secret and select Delete.
In the Delete resource confirmation dialog enter the name of the secret and select OK to confirm.
Repeat steps 4 and 5 for the remaining secrets.
In the dapr app details tree, locate the mutatingwebhookconfiguration.
Note:You can recognize the mutatingwebhookconfiguration from the label MWC.
Open the context menu of the secret and select Delete. In the Delete resource confirmation dialog enter the name of the mutatingwebhookconfiguration and select OK to confirm.
Some of the secrets are immediately recreated. This is indicated by a green check mark on the secret card. If a secret is not recreated, you need to sync to recreate the secret.
Locate the secret you want to recreate and select Sync from the context menu.
In the pop-up panel, select SYNCHRONIZE.
Repeat steps 2 and 3 for all the secrets that you want to recreate.
Open the context menu for the mutatingwebhookconfiguration and select Sync.
After you deleted and synchronized the secrets and the mutatingwebhookconfiguration, you need to restart the deployment.
In the dapr app details tree, locate the dapr-sentry deploy card.
A confirmation dialog is displayed.
Open the context menu and select Restart.
- Select OK to confirm the restart. The dapr-sentry deployment starts. When the deployment is finished, a green heart appears. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr-operator deploy card.
In the confirmation dialog, select OK to confirm the restart. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr- sidecar-injector deploy card.
Restart the deployments in the described order and make sure a deployment is ready before starting the next deployment.
dapr-sentry
dapr-operator
