- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Accessing Automation Suite
- Managing the certificates
- Updating the SQL connection strings
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
There are multiple scenarios where you may want to update the connection string used by Automation Suite products to connect to the SQL database, such as the following:
- When periodically rotating the password used to connect to the database, for security and compliance;
- When changing the FQDN for the SQL server;
- When migrating the database to another SQL server for maintenance purposes;
- When adding, modifying, or removing one or more connection attributes, such as
MultiSubnetFailover
; - When switching from basic authentication to integrated authentication using Kerberos and AD.
Important:
Products in Automation Suite do not create tables or schema at the time of updating the SQL database connection string. Make sure your new connection string refers to the same database that you currently use.
To avoid downtime during the update process, make sure that your current connection string is valid at the time of the update process. You can revoke your old connection string after the update.
- If you use the Account lockout threshold policy setting, enable maintenance mode.
- Generate the
cluster_config.json
file. - Provide the new connection strings for the installed products in the cluster_config.json.
- Run the service installer.
- If you use the Account lockout threshold policy setting, disable maintenance mode.
Generate the latest cluster_config.json file using the following command:
uipathctl manifest get-revision >> ./cluster_config.json
There are two ways to provide the connection strings for products running in Automation Suite:
A: Provide a connection string template that will be common to all the products running in Automation Suite. This approach will assume the default database names for all the products.
B: Provide connection strings specific to each product.
Make sure you escape NET, JDBC, or ODBC passwords as follows:
for NET: add
at the beginning and end of the password, and double any other'
for JDBC/ODBC: add
at the beginning of the password and}
at the end, and double any other}
TrustServerCertificate=False
, then you may have to provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate
is self-signed or signed by an internal CA. For details, see Updating the CA certificates.
A: Providing a common connection string for all products
All the products running in Automation Suite refer to a common template connection string. One use case for choosing this method would be when you want to change the password for all the products at once. Note that, in this case, the password will be the same for all the products.
In this scenarios, the database names for all products must be the default ones, as required by Automation Suite. If the database names you configured do not meet the Automation Suite requirements, follow the next step.
Check the list of the databases and their default names:
Single-node evaluation:
Multi-node HA-ready production: Configuring Microsoft SQL Server
The following table explains which template format the product services accept:
Parameter |
Description |
Products |
Full ADO.NET connection string where Catalog name is set to
DB_NAME_PLACEHOLDER . The installer will replace this placeholder with the default database names for the installed suite services.
Platform, Orchestrator, Automation Suite Robots, Test Manager, Automation Hub, Automation Ops, Insights, Task Mining, Data Service, Process Mining |
Full JDBC connection string where database name is set to
AI Center 1 |
Full ODBC connection string where database name is set to
Document Understanding, Apps |
sql_connection_string_template_sqlalchemy_pyodbc | Full SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER . The installer will replace this placeholder with the default database names for the installed suite services.
Example:
Process Mining |
sql_connection_string_template_jdbc
: encrypt=true;trustServerCertificate=false;fips=true;
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
"mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
cluster_config.json
with the new connection string template you want to update.
B: Providing connection strings specific to each product
Platform
AutomationSuite_Platform
cluster_config.json
file:
"platform": {
"sql_connection_str": "***" // dotnet connection string
"platform": {
Orchestrator
AutomationSuite_Orchestrator
cluster_config.json
file:
"orchestrator": {
"orchestrator": {
cluster_config.json
file:
"asrobots": {
"asrobots": {
Automation Hub
AutomationSuite_Automation_Hub
cluster_config.json
file:
"automation_hub": {
"automation_hub": {
Automation Ops
cluster_config.json
file:
"automation_ops": {
"automation_ops": {
AI Center
AutomationSuite_AICenter
cluster_config.json
file:
"aicenter": {
"sql_connection_str": "***" // jdbc connection string
"aicenter": {
Apps
AutomationSuite_Apps
cluster_config.json
file:
"apps": {
"sql_connection_str": "***" // odbc connection string
"apps": {
Data Service
AutomationSuite_DataService
cluster_config.json
file:
"dataservice": {
"dataservice": {
AutomationSuite_DU_Datamanager
cluster_config.json
file:
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
"enabled": true,
"datamanager": {
Insights
AutomationSuite_Insights
cluster_config.json
file:
"insights": {
"insights": {
Process Mining
AutomationSuite_ProcessMining_Metadata
cluster_config.json
file:
"process_mining": {
"enabled": true,
"sqlalchemy_pyodbc_sql_connection_str": "",
"warehouse": {
"sql_connection_str": "",
"master_sql_connection_str": "",
"process_mining": {
"enabled": true,
"warehouse": {
Task Mining
AutomationSuite_Task_Mining
cluster_config.json
file:
"task_mining": {
"task_mining": {
Test Manager
AutomationSuite_Test_Manager
cluster_config.json
file:
"test_manager": {
"test_manager": {
To run the service installer, use the following command:
cd /opt/UiPathAutomationSuite/{version}/installer
./install-uipath.sh -i ./cluster_config.json -s -o output.json --accept-license-agreement
