Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Remapping the organization IDs
- Migrating Looker data to Automation Suite
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
To migrate from standalone Insights to Automation Suite, you must remap of the organization IDs in the following tables:
[Id] [int] NOT NULL,
[Key] [nvarchar](128) NOT NULL,
[Name] [nvarchar](128) NOT NULL,
[IsActive] [bit] NOT NULL,
[IsDeleted] [bit] NOT NULL,
[OrganizationId] [nvarchar](128) NULL,
CONSTRAINT [PK_dbo.Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsintegrations].[TenantServiceIntegrations](
[Id] [uniqueidentifier] NOT NULL,
[TenantId] [uniqueidentifier] NOT NULL,
[OrganizationId] [uniqueidentifier] NOT NULL,
[ServiceName] [int] NOT NULL,
[Status] [int] NOT NULL,
[CreationTime] [datetime2](7) NOT NULL,
[LastUpdatetime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantServiceIntegrations] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[GroupRoles](
[GroupId] [uniqueidentifier] NOT NULL,
[RoleId] [uniqueidentifier] NOT NULL,
CONSTRAINT [PK_GroupRoles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Groups](
[Name] [nvarchar](max) NULL,
[Email] [nvarchar](max) NULL,
CONSTRAINT [PK_Groups] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Roles](
[TenantId] [uniqueidentifier] NULL,
[Resource] [nvarchar](max) NULL,
CONSTRAINT [PK_Roles] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[TenantGroups](
[TimeProcessed] [datetime2](7) NULL,
[LastUpdateTime] [datetime2](7) NOT NULL,
CONSTRAINT [PK_TenantGroup] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Tenants](
CONSTRAINT [PK_Tenants] PRIMARY KEY CLUSTERED
CREATE TABLE [insightspermissions].[Users](
[IsDeleted] [bit] NULL,
CONSTRAINT [PK_Users] PRIMARY KEY CLUSTERED
CREATE TABLE [insightsprovisioning].[TenantInstances](
[ServiceType] [nvarchar](max) NULL,
[State] [int] NOT NULL,
[TenantName] [nvarchar](max) NULL,
CONSTRAINT [PK_TenantInstances] PRIMARY KEY CLUSTERED
CREATE TABLE [read].[HASHKEYS](
[hashkey] [bigint] NOT NULL,
[tenantkey] [nvarchar](128) NOT NULL,
[tenantname] [nvarchar](256) NULL,
[organizationid] [nvarchar](128) NULL,
[status] [int] NULL
[status] [int] NULL
[dbo].[Tenants]
[read].[HASHKEYS]
[dbo].[Tenants]
[read].[HASHKEYS]
Tip: Below you have an example on how to update the tables:
--- Script to replace MSI organization ID with AS organization ID.
--- Please update the following DECLARE statements with your corresponding MSI org ID and AS org ID before executing this script.
DECLARE @msi_organization_id nvarchar(500) = upper('687db434-ce5c-4058-bc0b-3ed3fa23882b');
DECLARE @as_organization_id nvarchar(500) = upper('AA259F1A-5828-4608-AF71-27177A7831B8');
DECLARE @msi_resource nvarchar(500) = lower('insights/687db434-ce5c-4058-bc0b-3ed3fa23882b/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
DECLARE @as_resource nvarchar(500) = lower('insights/aa259f1a-5828-4608-af71-27177a7831b8/687db434-ce5c-4058-bc0b-3ed3fa23882b/*');
SELECT * FROM [dbo].[Tenants];
UPDATE [dbo].[Tenants]
SET OrganizationId = lower(@as_organization_id)
WHERE OrganizationId = lower(@msi_organization_id);
SELECT * FROM [insightsintegrations].[TenantServiceIntegrations];
UPDATE [insightsintegrations].[TenantServiceIntegrations]
SET OrganizationId = @as_organization_id
WHERE OrganizationId = @msi_organization_id;
ALTER TABLE [insightspermissions].[GroupRoles] NOCHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[GroupRoles];
UPDATE [insightspermissions].[GroupRoles]
ALTER TABLE [insightspermissions].[GroupRoles] CHECK CONSTRAINT FK_GroupRoles_Groups_GroupId_OrganizationId;
ALTER TABLE [insightspermissions].[TenantGroups] NOCHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[TenantGroups];
UPDATE [insightspermissions].[TenantGroups]
ALTER TABLE [insightspermissions].[TenantGroups] CHECK CONSTRAINT FK_TenantGroups_Groups_GroupId_OrganizationId;
SELECT * FROM [insightspermissions].[Groups];
UPDATE [insightspermissions].[Groups]
SELECT * FROM [insightspermissions].[Roles];
UPDATE [insightspermissions].[Roles]
SET Resource = @as_resource
WHERE Resource = @msi_resource;
SELECT * FROM [insightspermissions].[Tenants];
UPDATE [insightspermissions].[Tenants]
SELECT * FROM [insightspermissions].[Users];
UPDATE [insightspermissions].[Users]
SELECT * FROM [insightsprovisioning].[TenantInstances];
UPDATE [insightsprovisioning].[TenantInstances]
SELECT * FROM [read].[HASHKEYS];
UPDATE [read].[HASHKEYS]
