- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Rotating Blob Storage Credentials
- Disabling use of pre-signed URLs when uploading data to Amazon S3 storage
- Configuring process app security
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
To rotate the blob storage credentials for Process Mining in Automation Suite an administrator will need to have access to the Kubernetes cluster secrets using either kubectl, lens, or another tool. The stored secrets detailed below must be updated with the new credentials, and the the pods for Airflow and Process Mining need to be restarted to make sure all pods for these service receive the new credentials.
Below is an examples of how to update secrets with kubectl:
kubectl patch secret processmining-external-storage-secret -n uipath -p "{\"data\":{\"ACCOUNTKEY\":\"<new_key_b64>\"}}"
UiPath Namespace
processmining-service-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
processmining-service-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
Airflow Namespace
airflow-rook-ceph-secret.OBJECT_STORAGE_ACCESSKEY
airflow-rook-ceph-secret.OBJECT_STORAGE_SECRETKEY
ceph-object-store-secret.OBJECT_STORAGE_ACCESSKEY
ceph-object-store-secret.OBJECT_STORAGE_SECRETKEY
UiPath Namespace
processmining-external-storage-secret.ACCESSKEY
processmining-external-storage-secret.SECRETKEY
Airflow NameSpace
processmining-external-storage-secret.connection
UiPath Namespace
Airflow NameSpace
UiPath Namespace
processmining-external-storage-secret.ACCOUNTNAME
processmining-external-storage-secret.ACCOUNTKEY
Airflow Namespace
urlencode -d "wasb%3A%2F%2Fazureuser%40%3Fextra__wasb__connection_string%3DDefaultEndpointsProtocol%3Dhttps%3BEndpointSuffix%3Dcore.windows.net%3BAccountName%3Dazureuser%3BAccountKey%3DACCOUNT_KEY%3BBlobEndpoint%3Dhttps%3A%2F%2Fexample.blob.core.windows.net%2F%3BFileEndpoint%3Dhttps%3A%2F%2Fexample.file.core.windows.net%2F%3BQueueEndpoint%3Dhttps%3A%2F%2Fexample.queue.core.windows.net%2F%3BTableEndpoint%3Dhttps%3A%2F%2Fexample.table.core.windows.net%2F%26extra__wasb__sas_token%3D%26extra__wasb__shared_access_key%3D%26extra__wasb__tenant_id%3D"
urlencode "wasb://azureuser@?extra__wasb__connection_string=DefaultEndpointsProtocol=https;EndpointSuffix=core.windows.net;AccountName=azureuser;AccountKey=ACCOUNT_KEY;BlobEndpoint=https://example.blob.core.windows.net/;FileEndpoint=https://example.file.core.windows.net/;QueueEndpoint=https://example.queue.core.windows.net/;TableEndpoint=https://example.table.core.windows.net/&extra__wasb__sas_token=&extra__wasb__shared_access_key=&extra__wasb__tenant_id="
