Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
documentunderstanding
is a property in the Automation Suite's configuration file, cluster_config.json
. It contains configurable values that control the behavior of the Document Understanding service. The installer generates
the default values. Additional changes can be made to further configure the Document Understanding service. If you need to
change any settings related to Document Understanding, the documentunderstanding
section in cluster_config.json
can be edited and the installer can be re-run.
Alternatively, the same changes can be made in the UiPath® app in ArgoCD.
"documentunderstanding": {
"enabled": Boolean,
"datamanager": {
"sql_connection_str" : "String"
"handwriting": {
"enabled": Boolean,
"max_cpu_per_pod": "Number"
"enabled": Boolean,
"datamanager": {
"handwriting": {
"enabled": Boolean,
Note:
The data manager SQL connection string is optional only if you want to overwrite the default database with your own.
Handwriting is always enabled for online installation.
"enabled": true,
"datamanager": {
"sql_connection_str": "mssql+pyodbc://testadmin:myPassword@mydev-sql.database.windows.net:1433/datamanager?driver=ODBC+Driver+17+for+SQL+Server",
"handwriting": {
"enabled": true,
"max_cpu_per_pod": "2"
"enabled": true,
"datamanager": {
"handwriting": {
"enabled": true,
Note: The value for
max_cpu_per_pod
is by default 2
, but it can be adjusted according to your needs. For more information on how to do this, see the (optional) max CPU per pod Parameter section.
- Connection string for datamanager
- Required: False.
- This property is generated and populated by the installer, you do not need to set it unless you want to override the default connection string. For more details about connecting to SQL please refer to the Using the configuration file page.
- Settings for the handwriting recognition functionality (part of IntelligentFormExtractor)
- Required: False.
- Setting this to true creates the resources necessary for performing handwriting recognition. This needs to be true to use IntelligentFormExtractor.
- Required: False
- This property is always enabled for online installation, and disabled for offline (air-gapped) installation. For air-gapped installation, you need to install the Document Understanding offline bundle before enabling handwriting.
- The maximum amount of CPUs each container is allowed to use. The recommended value is 2.
- Required: False.
- Default: 2.
If you plan to use Intelligent Form Extractor with handwriting detection feature, you may need to adjust the
handwriting.max_cpu_per_pod
parameter for more processing power.
The following factors are required to calculate the right sizing:
- total volume of documents/year = V
- expected number of handwriting shreds/doc = S
- days in which the workflow processes documents (workdays, all days, weekends, etc) = d
- hours in which the workflow processes documents = h
- Number of CPUs = (V x S / (d x h)) / 1500
As an example, if you expect to have 1 million documents to process for a year using Intelligent Form Extractor for handwriting detection, with 50 shreds on average, running weekdays from 00:00 to 08:00 (8hr), the calculation would be:
Number of CPUs = (1,000,000 x 50 / (250 x 8)) / 1500
= 25,000 / 1500
= 17 CPUs
= 25,000 / 1500
= 17 CPUs
For the single-node evaluation mode, you need to adjust the
max_cpu_per_pod
parameter to 17.
For the multi-node HA-ready production mode (3 nodes), adjust the
max_cpu_per_pod
parameter to 5-6.
