Automation Suite
- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Redirecting traffic for the unsupported services to the primary cluster
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- B) Single tenant migration
- Upgrading Automation Suite
- Migrating to an external OCI-compliant registry
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining and Task Mining
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated May 20, 2024
If you upgrade from Automation Suite 2022.10 to Automation Suite 2023.4 or later, and Orchestrator is enabled on both the
old and new versions, you must set the
orchestrator.block_classic_executions
flag to true
in the cluster_config.json
file. Using the flag shows that you agree with blocking classic folders executions. Not using the flag causes the upgrade
operation to fail. This parameter is not required in new installations.
By default, Orchestrator uses the cluster storage, where data for all services and all tenants is stored in a single bucket.
However, Orchestrator storage options can be customized separately from the cluster storage. This explicit configuration allows
you to modify the settings in such a way that they emulate a previous Orchestrator version, where data for each tenant was
stored in a separate bucket. You can configure this functionality in the
orchestrator.legacy_object_storage
section. For more information about configuring the Orchestrator object storage, see Overriding cluster-level storage configuration.
Orchestrator can save robot logs to an Elasticsearch server. You can configure this functionality in the
orchestrator.orchestrator_robot_logs_elastic
section. If not provided, robot logs are saved to Orchestrator's database. For more information, see Basic robot log Elasticsearch configuration.
Encryption key per tenant is configured in two steps:
Add the basic configuration to the configuration file. To do that, edit the file's
orchestrator.encryption_key_per_tenant
section. -
Enable the encryption key per tenant in the Orchestrator specific configuration (post installation).
For more information, see Configuring encryption key per tenant.
"orchestrator": {
"enabled": true,
"block_classic_executions": true,
"orchestrator_robot_logs_elastic": {
"elastic_uri": "https://elastic.example.com:9200",
"elastic_auth_username": "elastic-user",
"elastic_auth_password": "elastic-password"
"legacy_object_storage": {
"type": "Azure",
"connection_string": "DefaultEndpointsProtocol=https;AccountName=usr;AccountKey=...;EndpointSuffix=core.windows.net"
"encryption_key_per_tenant": {
"certificate_base_64": "",
"certificate_password": "",
"client_id": "",
"directory_id": "",
"vault_address": ""
"orchestrator": {
"enabled": true,
"type": "Azure",
"client_id": "",
"directory_id": "",
"vault_address": ""
